I'm trying to do face recognition on an esp-eye and set it up with home-assistant for presence detection.
So far I'm having trouble running the example code examples/human_face_recognition getting this error:
I (27) boot: ESP-IDF v4.3.1-dirty 2nd stage bootloader
I (27) boot: compile time 10:58:06
I (27) boot: chip revision: 1
I (30) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (37) qio_mode: Enabling default flash chip QIO
I (43) boot.esp32: SPI Speed : 80MHz
I (47) boot.esp32: SPI Mode : QIO
I (52) boot.esp32: SPI Flash Size : 4MB
I (56) boot: Enabling RNG early entropy source...
I (62) boot: Partition Table:
I (65) boot: ## Label Usage Type ST Offset Length
I (73) boot: 0 factory factory app 00 00 00010000 003c0000
I (80) boot: 1 nvs WiFi data 01 02 003d0000 00004000
I (88) boot: 2 fr unknown 20 20 003e0000 00020000
I (95) boot: End of partition table
I (99) boot_comm: chip revision: 1, min. application chip revision: 0
I (106) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=2abb04h (2800388) map
I (945) esp_image: segment 1: paddr=002bbb2c vaddr=3ffbdb60 size=04210h ( 16912) load
I (950) esp_image: segment 2: paddr=002bfd44 vaddr=40080000 size=002d4h ( 724) load
I (951) esp_image: segment 3: paddr=002c0020 vaddr=400d0020 size=79dech (499180) map
I (1107) esp_image: segment 4: paddr=00339e14 vaddr=400802d4 size=14e10h ( 85520) load
I (1136) esp_image: segment 5: paddr=0034ec2c vaddr=50000000 size=00010h ( 16) load
I (1147) boot: Loaded app from partition at offset 0x10000
I (1148) boot: Disabling RNG early entropy source...
I (1159) psram: This chip is ESP32-D0WD
I (1160) spiram: Found 64MBit SPI RAM device
I (1160) spiram: SPI RAM mode: flash 80m sram 80m
I (1165) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (1172) cpu_start: Pro cpu up.
I (1176) cpu_start: Starting app cpu, entry point is 0x400816fc
0x400816fc: call_start_cpu1 at C:/repo/esp/esp-idf/components/esp_system/port/cpu_start.c:141
I (0) cpu_start: App cpu up.
I (1673) spiram: SPI SRAM memory test OK
I (1681) cpu_start: Pro cpu start user code
I (1681) cpu_start: cpu freq: 240000000
I (1681) cpu_start: Application information:
I (1684) cpu_start: Project name: human_face_recognition_terminal
I (1691) cpu_start: App version: v0.9.3-125-g0135616-dirty
I (1698) cpu_start: Compile time: Nov 25 2021 10:57:47
I (1704) cpu_start: ELF file SHA256: 8ec99ddccb1f76bd...
I (1710) cpu_start: ESP-IDF: v4.3.1-dirty
I (1716) heap_init: Initializing. RAM available for dynamic allocation:
I (1723) heap_init: At 3FFAE6E0 len 0000F480 (61 KiB): DRAM
I (1729) heap_init: At 3FFC6FD0 len 00019030 (100 KiB): DRAM
I (1736) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1742) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1749) heap_init: At 400950E4 len 0000AF1C (43 KiB): IRAM
I (1755) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (1763) spi_flash: detected chip: generic
I (1768) spi_flash: flash io: qio
I (1782) cpu_start: Starting scheduler on PRO CPU.
I (1783) who_camera: Camera module is Wrover Kit
I (1783) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:2
I (1793) cam_hal: cam init ok
I (1793) sccb: pin_sda 26 pin_scl 27
E (1883) camera: Camera probe failed with error 0x105(ESP_ERR_NOT_FOUND)
E (1883) who_camera: Camera init failed with error 0x105
I (1883) gpio: GPIO[0]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:3
E (1893) gpio: gpio_install_isr_service(460): GPIO isr service already installed
In the menuconfig I tried to select both WROVER-kit, ESP-EYE, ESP-S3-EYE all failing on "GPIO isr service already installed".
Anyone who can help with this?
![Smile :-)](./images/smilies/icon_e_smile.gif)
