ESP-WHO 二维例子下载到官方开发板ESP32-S3-EYE 开发板子可以识别出二维码,
宏定义修改相机的IO配置口下载到自己的板子上确运行不通过,一直重启打印如下信息
[18:25:25.165]收←◆ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x10 (RTCWDT_RTC_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x17b0
load:0x403c9700,len:0xe64
load:0x403cc700,len:0x30d8
entry 0x403c9980
[0;32mI (25) boot: ESP-IDF v4.4.2-dirty 2nd stage bootloader[0m
[0;32mI (25) boot: compile time 17:51:10[0m
[0;32mI (25) boot: chip revision: 0[0m
[0;32mI (27) qio_mode: Enabling default flash chip QIO[0m
[0;32mI (33) boot.esp32s3: Boot SPI Speed : 80MHz[0m
[0;32mI (38) boot.esp32s3: SPI Mode : QIO[0m
[0;32mI (42) boot.esp32s3: SPI Flash Size : 8MB[0m
[0;32mI (47) boot: Enabling RNG early entropy source...[0m
[0;32mI (52) boot: Partition Table:[0m
[0;32mI (56) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (63) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (71) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (78) boot: 2 factory factory app 00 00 00010000 00100000[0m
[0;32mI (86) boot: End of partition table[0m
[0;32mI (90) esp_image: segment 0: paddr=00010020 vaddr=3c040020 size=3d428h (250920) map[0m
[18:25:25.309]收←◆[0;32mI (136) esp_image: segment 1: paddr=0004d450 vaddr=3fc930f0 size=02bc8h ( 11208) load[0m
[0;32mI (139) esp_image: segment 2: paddr=00050020 vaddr=42000020 size=32b58h (207704) map[0m
[0;32mI (174) esp_image: segment 3: paddr=00082b80 vaddr=3fc95cb8 size=01088h ( 4232) load[0m
[0;32mI (175) esp_image: segment 4: paddr=00083c10 vaddr=40374000 size=0f0f0h ( 61680) load[0m
[0;32mI (191) esp_image: segment 5: paddr=00092d08 vaddr=50000000 size=00010h ( 16) load[0m
[0;32mI (198) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (198) boot: Disabling RNG early entropy source...[0m
[0;32mI (211) opi psram: vendor id : 0x00 (UNKNOWN)[0m
[0;32mI (211) opi psram: dev id : 0x03 (generation 4)[0m
[0;32mI (212) opi psram: density : 0x07 (256 Mbit)[0m
[0;32mI (216) opi psram: good-die : 0x01 (Pass)[0m
[0;32mI (220) opi psram: Latency : 0x01 (Fixed)[0m
[0;32mI (225) opi psram: VCC : 0x01 (3V)[0m
[0;32mI (230) opi psram: SRF : 0x00 (Slow Refresh)[0m
[0;32mI (235) opi psram: BurstType : 0x01 ( Wrap)[0m
[0;32mI (240) opi psram: BurstLen : 0x03 (1024 Byte)[0m
[0;32mI (245) opi psram: Readlatency : 0x07 (20 cycles@Fixed)[0m
[0;32mI (251) opi psram: DriveStrength: 0x03 (1/8)[0m
[0;33mW (256) PSRAM: DO NOT USE FOR MASS PRODUCTION! Timing parameters will be updated in future IDF version.[0m
[0;33mW (267) MSPI Timing: tuning fail, best point is fallen back to index 1[0m
[0;32mI (274) spiram: Found 256MBit SPI RAM device[0m
[0;32mI (279) spiram: SPI RAM mode: sram 80m[0m
[0;32mI (283) spiram: PSRAM initialized, cache is in normal (1-core) mode.[0m
这是什么原因呢?
ESP-WHO 的二维码例子下载到自己的板子运行出错
Users browsing this forum: No registered users and 12 guests
