RTOS task 修改變量
Posted: Thu Sep 30, 2021 3:26 am
如果RTOS TASK在運行之後可以修改變量嗎?我想用GOLBALVARIABLE 去設定RTOS TASK內的變量但好像不可以改變量的值。
TaskHandle_t Task0;
TaskHandle_t Task1;
QueueHandle_t queue;
#define LED0 27
#define LED1 25
#define SWITCH 2
void loop0(void * parameter) {
for (;;) {
// Add a random number to the queue
// auto rndNumber = esp_random();
// Use Arduino implementation for a number between limits
int rndNumber = random(1, 9);
// Add to the queue - wait forever until space is available
Serial.println("\t\t\t\t\tMgr 0 - Adding " + String(rndNumber) + " to queue");
xQueueSend(queue, &rndNumber, portMAX_DELAY);
// Artificial wait here
digitalWrite(LED0, HIGH);
delay(200);
digitalWrite(LED0, LOW);
delay(500);
// Slow motion delay here
//delay(5000);
// Force a tea-break here if switch is pressed
bool TeaBreak = false;
while (digitalRead(SWITCH) == LOW){
delay(100);
if (!TeaBreak) {
Serial.println("\t\t\t\t\tMgr 0 - Tea Break");
TeaBreak = true;
void loop1(void * parameter) {
for (;;) {
// Get the number of flashes required
int flashTotal;
xQueueReceive(queue, &flashTotal, portMAX_DELAY);
Serial.println("Worker - reading " + String(flashTotal));
// Flash that number
for (int cnt = 0; cnt < flashTotal; cnt++) {
digitalWrite(LED1, HIGH);
delay(150);
digitalWrite(LED1, LOW);
delay(150);
//delay(1000);
void setup()
Serial.begin(115200);
Serial.println("Setup started.");
pinMode(LED0, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(SWITCH, INPUT_PULLUP);
// Create the queue with 5 slots of 2 bytes
queue = xQueueCreate(5, sizeof(int));
xTaskCreatePinnedToCore(
loop0, /* Function to implement the task */
"Task0", /* Name of the task */
1000, /* Stack size in words */
NULL, /* Task input parameter */
0, /* Priority of the task */
&Task0, /* Task handle. */
1); /* Core where the task should run */
loop1, /* Function to implement the task */
"Task1", /* Name of the task */
&Task1, /* Task handle. */
Serial.println("Setup completed.");
void loop()
vTaskDelete (NULL);
