ESP32-LyraT V4.3 的Dueros编译下载后,不断重启问题
Posted: Tue Dec 31, 2019 7:30 am
by zhangyadong
串口打印信息如下:
看不出来是因为啥引起的重启,模块是ESP32 WROVER B
PS:编译下载paly_mp3工程是正常的。
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:6616
load:0x40078000,len:11116
load:0x40080400,len:6004
entry 0x40080704
[0;32mI (61) boot: Chip Revision: 1[0m
[0;32mI (64) boot_comm: chip revision: 1, min. bootloader chip revision: 0[0m
[0;32mI (39) boot: ESP-IDF v3.3.1-dirty 2nd stage bootloader[0m
[0;32mI (39) boot: compile time 14:24:02[0m
[0;32mI (40) boot: Enabling RNG early entropy source...[0m
[0;32mI (45) boot: SPI Speed : 80MHz[0m
[0;32mI (49) boot: SPI Mode : DIO[0m
[0;32mI (53) boot: SPI Flash Size : 4MB[0m
[0;32mI (57) boot: Partition Table:[0m
[0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m
[0;32mI (68) boot: 0 nvs WiFi data 01 02 00009000 00006000[0m
[0;32mI (75) boot: 1 phy_init RF data 01 01 0000f000 00001000[0m
[0;32mI (83) boot: 2 factory factory app 00 00 00010000 00300000[0m
[0;32mI (90) boot: End of partition table[0m
[0;32mI (95) boot_comm: chip revision: 1, min. application chip revision: 0[0m
[0;32mI (102) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x75b2c (482092) map[0m
[0;32mI (245) esp_image: segment 1: paddr=0x00085b54 vaddr=0x3ffb0000 size=0x03cdc ( 15580) load[0m
[0;32mI (250) esp_image: segment 2: paddr=0x00089838 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (252) esp_image: segment 3: paddr=0x00089c40 vaddr=0x40080400 size=0x063d0 ( 25552) load[0m
[0;32mI (269) esp_image: segment 4: paddr=0x00090018 vaddr=0x400d0018 size=0x13ca9c (1297052) map[0m
[0;32mI (630) esp_image: segment 5: paddr=0x001ccabc vaddr=0x400867d0 size=0x11380 ( 70528) load[0m
[0;32mI (669) boot: Loaded app from partition at offset 0x10000[0m
[0;32mI (669) boot: Disabling RNG early entropy source...[0m
[0;31mE (669) psram: Not a valid or known package id: 3[0m
abort() was called at PC 0x40082c6b on core 0
ELF file SHA256: ad532c0faae02628277b01ecab20d4cb04ca7d5c81e3ac4ab33a11f693b49050
Backtrace: 0x4008b4db:0x3ffe3b70 0x4008b82d:0x3ffe3b90 0x40082c6b:0x3ffe3bb0 0x400d3fbf:0x3ffe3c20 0x400815f3:0x3ffe3c40 0x40079366:0x3ffe3c80 0x40079839:0x3ffe3cc0 0x40080759:0x3ffe3df0 0x40007c31:0x3ffe3eb0 0x4000073d:0x3ffe3f20
Rebooting...
Re: ESP32-LyraT V4.3 的Dueros编译下载后,不断重启问题
Posted: Fri May 07, 2021 9:22 am
by wangpengXX
这个解决了吗?我也遇到了?是因为profile?
Posted: Thu May 13, 2021 8:13 am
by ESP_HengYC
从上述log, 你的这个问题似乎是 psram  检测异常造成的。
看了你的开发板上面的模组,似乎是你自己更换成了 WROVER-B? 请使用源生的开发板重试下。
