ESP32-S3使用tcp_server例程,并将网络数据和串口数据透传延迟过高
Eltrion
Postby Eltrion » Mon Nov 20, 2023 3:37 pm
使用tcp_server例程修改,将tcp数据与串口数据进行透传,串口→tcp的数据延迟很低,基本都在10ms以内,但是tcp→串口的数据延迟就很高,会达到100ms以上,回环测试的延迟也在60ms以上,通过逻辑分析仪抓取到大部分时间耗费在recv函数上,请问下这种问题是在idf里普遍存在的还是我的工程设置有问题或者环境原因?但是在使用modbus TCP例程的时候,返回数据的延迟却特别低,基本都在5ms以内。
以下是代码,工程由v5.1创建
/* BSD Socket API Example
#include <string.h>
#include <sys/param.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "esp_netif.h"
#include "protocol_examples_common.h"
#include "lwip/err.h"
#include "lwip/sockets.h"
#include "lwip/sys.h"
#include <lwip/netdb.h>
#include "driver/uart.h"
#include "driver/gpio.h"
#define PORT                        CONFIG_EXAMPLE_PORT
#define KEEPALIVE_IDLE              CONFIG_EXAMPLE_KEEPALIVE_IDLE
#define KEEPALIVE_INTERVAL          CONFIG_EXAMPLE_KEEPALIVE_INTERVAL
#define KEEPALIVE_COUNT             CONFIG_EXAMPLE_KEEPALIVE_COUNT
static const char *TAG = "example";
int tcp_sock = 0;
QueueHandle_t uart_queue = NULL;
static void do_retransmit(const int sock)
    int len;
    char rx_buffer[128];
    do {
        len = recv(sock, rx_buffer, sizeof(rx_buffer) - 1, 0);
        if (len < 0)
            ESP_LOGE(TAG, "Error occurred during receiving: errno %d", errno);
        else if (len == 0)
            ESP_LOGW(TAG, "Connection closed");
        else
            uart_write_bytes(UART_NUM_1, rx_buffer, len);
            rx_buffer[len] = 0; // Null-terminate whatever is received and treat it like a string
            ESP_LOGI(TAG, "Received %d bytes: %s", len, rx_buffer);
            int to_write = len;
            while (to_write > 0) {
                int written = send(sock, rx_buffer + (len - to_write), to_write, 0);
                if (written < 0) {
                    ESP_LOGE(TAG, "Error occurred during sending: errno %d", errno);
                    // Failed to retransmit, giving up
                    return;
                to_write -= written;
    } while (len > 0);
static void tcp_server_task(void *pvParameters)
    char addr_str[128];
    int addr_family = (int)pvParameters;
    int ip_protocol = 0;
    int keepAlive = 1;
    int keepIdle = KEEPALIVE_IDLE;
    int keepInterval = KEEPALIVE_INTERVAL;
    int keepCount = KEEPALIVE_COUNT;
    struct sockaddr_storage dest_addr;
#ifdef CONFIG_EXAMPLE_IPV4
    if (addr_family == AF_INET) {
        struct sockaddr_in *dest_addr_ip4 = (struct sockaddr_in *)&dest_addr;
        dest_addr_ip4->sin_addr.s_addr = htonl(INADDR_ANY);
        dest_addr_ip4->sin_family = AF_INET;
        dest_addr_ip4->sin_port = htons(PORT);
        ip_protocol = IPPROTO_IP;
#endif
#ifdef CONFIG_EXAMPLE_IPV6
    if (addr_family == AF_INET6) {
        struct sockaddr_in6 *dest_addr_ip6 = (struct sockaddr_in6 *)&dest_addr;
        bzero(&dest_addr_ip6->sin6_addr.un, sizeof(dest_addr_ip6->sin6_addr.un));
        dest_addr_ip6->sin6_family = AF_INET6;
        dest_addr_ip6->sin6_port = htons(PORT);
        ip_protocol = IPPROTO_IPV6;
#endif
    int listen_sock = socket(addr_family, SOCK_STREAM, ip_protocol);
    if (listen_sock < 0) {
        ESP_LOGE(TAG, "Unable to create socket: errno %d", errno);
        vTaskDelete(NULL);
        return;
    int opt = 1;
    setsockopt(listen_sock, SOL_SOCKET, SO_REUSEADDR, &opt, sizeof(opt));
#if defined(CONFIG_EXAMPLE_IPV4) && defined(CONFIG_EXAMPLE_IPV6)
    // Note that by default IPV6 binds to both protocols, it is must be disabled
    // if both protocols used at the same time (used in CI)
    setsockopt(listen_sock, IPPROTO_IPV6, IPV6_V6ONLY, &opt, sizeof(opt));
#endif
    ESP_LOGI(TAG, "Socket created");
    int err = bind(listen_sock, (struct sockaddr *)&dest_addr, sizeof(dest_addr));
    if (err != 0) {
        ESP_LOGE(TAG, "Socket unable to bind: errno %d", errno);
        ESP_LOGE(TAG, "IPPROTO: %d", addr_family);
        goto CLEAN_UP;
    ESP_LOGI(TAG, "Socket bound, port %d", PORT);
    err = listen(listen_sock, 1);
    if (err != 0) {
        ESP_LOGE(TAG, "Error occurred during listen: errno %d", errno);
        goto CLEAN_UP;
    while (1) {
        ESP_LOGI(TAG, "Socket listening");
        struct sockaddr_storage source_addr; // Large enough for both IPv4 or IPv6
        socklen_t addr_len = sizeof(source_addr);
        int sock = accept(listen_sock, (struct sockaddr *)&source_addr, &addr_len);
        if (sock < 0) {
            ESP_LOGE(TAG, "Unable to accept connection: errno %d", errno);
        tcp_sock = sock;
        // Set tcp keepalive option
        setsockopt(sock, SOL_SOCKET, SO_KEEPALIVE, &keepAlive, sizeof(int));
        setsockopt(sock, IPPROTO_TCP, TCP_KEEPIDLE, &keepIdle, sizeof(int));
        setsockopt(sock, IPPROTO_TCP, TCP_KEEPINTVL, &keepInterval, sizeof(int));
        setsockopt(sock, IPPROTO_TCP, TCP_KEEPCNT, &keepCount, sizeof(int));
        // Convert ip address to string
        if (source_addr.ss_family == PF_INET) {
            inet_ntoa_r(((struct sockaddr_in *)&source_addr)->sin_addr, addr_str, sizeof(addr_str) - 1);
#endif
        if (source_addr.ss_family == PF_INET6) {
            inet6_ntoa_r(((struct sockaddr_in6 *)&source_addr)->sin6_addr, addr_str, sizeof(addr_str) - 1);
#endif
        ESP_LOGI(TAG, "Socket accepted ip address: %s", addr_str);
        do_retransmit(sock);
        shutdown(sock, 0);
        close(sock);
CLEAN_UP:
    close(listen_sock);
    vTaskDelete(NULL);
void diaodian()
void uart_read_task(void *arg)
    uart_event_t event;
    uint8_t uart_data[1024] = {0};
    while (1)
        if(xQueueReceive(uart_queue, (void*)&event, portMAX_DELAY))
            //接收到串口数据
            memset(uart_data, 0, sizeof(uart_data));
            switch (event.type)
            case UART_DATA:
                ESP_LOGI(TAG, "串口数据事件");
                uart_read_bytes(UART_NUM_1, uart_data, event.size, portMAX_DELAY);  //接收串口数据
                send(tcp_sock, uart_data, event.size, 0);   //发送数据到网口
            default:
                ESP_LOGI(TAG, "其他串口事件,事件类型:%d", event.type);
    vTaskDelete(NULL);
void app_main(void)
    uart_config_t uart_cfg = {
        .baud_rate = 115200,
        .flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
        .source_clk = UART_SCLK_DEFAULT,
    uart_driver_install(UART_NUM_1, 2 * 1024, 2 * 1024, 10, &uart_queue, 0);
    uart_param_config(UART_NUM_1, &uart_cfg);
    uart_set_pin(UART_NUM_1, GPIO_NUM_4, GPIO_NUM_5, -1, -1);
    xTaskCreate(uart_read_task, "read_task", 5 * 1024, NULL, 3, NULL);
    ESP_ERROR_CHECK(nvs_flash_init());
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
    xTaskCreate(tcp_server_task, "tcp_server", 4096, (void*)AF_INET, 5, NULL);
#endif
    xTaskCreate(tcp_server_task, "tcp_server", 4096, (void*)AF_INET6, 5, NULL);
#endif
下图是串口与tcp透传的时间
以下是使用modbus TCP例程的延迟时间
ralfak
Re: ESP32-S3使用tcp_server例程,并将网络数据和串口数据透传延迟过高
Postby ralfak » Tue Dec 05, 2023 4:00 pm
应该是无线网的问题,你ping一下试试,一来一回都是上百ms,而且wifi这个东西是半双工的
这是一个qmd,娱乐一下!
Eltrion
Postby Eltrion » Wed Dec 06, 2023 1:01 am
你好,我同时也试了不使用wifi,使用esp32s2+w5500通过有线以太网建立tcp服务器,延迟也基本是在60-100ms,连续发送数据的话延迟会更高,ping的延迟是2ms以内。
Users browsing this forum: No registered users and 59 guests
