ESP32-S3 启动时卡在一个地方,求解答
Posted: Tue Jun 27, 2023 9:15 am
by justin_wg
启动信息如下:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x28 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3810,len:0x17bc
load:0x403c9700,len:0xd68
load:0x403cc700,len:0x2f34
entry 0x403c9930
I (21) boot: ESP-IDF v5.0.2-dirty 2nd stage bootloader
I (22) boot: compile time 14:01:44
I (22) boot: chip revision: v0.1
I (24) qio_mode: Enabling QIO for flash chip WinBond
I (30) boot.esp32s3: Boot SPI Speed : 80MHz
I (35) boot.esp32s3: SPI Mode : QIO
I (39) boot.esp32s3: SPI Flash Size : 32MB
I (44) boot: Enabling RNG early entropy source...
I (49) boot: Partition Table:
I (53) boot: ## Label Usage Type ST Offset Length
I (60) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (68) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (75) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (83) boot: 3 factory factory app 00 00 00010000 01000000
I (90) boot: End of partition table
I (94) boot: Defaulting to factory image
I (99) esp_image: segment 0: paddr=00010020 vaddr=3c0a0020 size=c6d0f8h (13029624) map
I (2081) esp_image: segment 1: paddr=00c7d120 vaddr=3fc95400 size=02a2ch ( 10796) load
I (2084) esp_image: segment 2: paddr=00c7fb54 vaddr=40374000 size=004c4h ( 1220) load
I (2088) esp_image: segment 3: paddr=00c80020 vaddr=42000020 size=9f498h (652440) map
I (2195) esp_image: segment 4: paddr=00d1f4c0 vaddr=403744c4 size=10e94h ( 69268) load
I (2208) esp_image: segment 5: paddr=00d3035c vaddr=600fe000 size=00034h ( 52) load
I (2216) boot: Loaded app from partition at offset 0x10000
I (2216) boot: Disabling RNG early entropy source...
I (2218) cpu_start: Pro cpu up.
I (2221) cpu_start: Starting app cpu, e��
到了Starting app cpu那,后面应该是 entry地址的,但是没执行下去。
请教下是什么问题
Re: ESP32-S3 启动时卡在一个地方,求解答
Posted: Tue Jun 27, 2023 9:34 am
by justin_wg
用helloworld没这个问题
Posted: Fri Jun 30, 2023 3:23 am
by justin_wg
So cold this forum....
Posted: Tue Jul 18, 2023 9:51 am
by ESP_Penguin_Helper
你好,请问你实在运行哪个 example 吗?可不可以给我看一下你的代码?
