ESP32S2关闭ADC/DAC后重启
Posted: Wed Sep 22, 2021 9:23 am
by kaisey
【环境】idf版本4.4,
【问题】在需要省电的时候,我调用adc_digi_stop()和dac_digi_stop()关闭ADC/DAC功能,同时调用esp_now_set_wake_window(ESPNOW_WAKEUP_TIME_MS)用手任意触摸开发板的脚位,就会一直重启,
如果只调用adc_digi_stop()和dac_digi_stop()不会有异常,只调用esp_now_set_wake_window(ESPNOW_WAKEUP_TIME_MS)也不会有异常,两个都调用都会一直重启
menuconfig修改如下
	component config->
		ESP32S2-specific->
			CPU frequency->
				240MHZ
			RTC clock source->
				Internal 8MHz oscillator, divided by 256(~32kHz)
		Power Management->
			Support for power management->
				Enable dynamic frequency scaling (DFS) at startup
		WI-FI->
			Power Management for station at disconnected
		FreeRTOS->
			Tickless idle support
【部分日志】
ELF file SHA256: 86660b37867889e0
Rebooting...
ESP-ROM:esp32s2-rc4-20191025
Build:Oct 25 2019
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x400235e0
0x400235e0: esp_restart_noos at C:/Users/Administrator/Desktop/esp-idf/components/esp_system/port/soc/esp32s2/system_internal.c:112 (discriminator 1)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3ffe6100,len:0x1734
load:0x4004c000,len:0xa04
load:0x40050000,len:0x2b28
entry 0x4004c1f4
I (24) boot: ESP-IDF v4.4-dev-1254-g639e7ad49-dirty 2nd stage bootloader
I (24) boot: compile time 16:13:47
I (24) boot: chip revision: 0
I (28) boot.esp32s2: SPI Speed      : 80MHz
I (33) boot.esp32s2: SPI Mode       : DIO
I (38) boot.esp32s2: SPI Flash Size : 2MB
I (42) boot: Enabling RNG early entropy source...
I (48) boot: Partition Table:
I (51) boot: ## Label            Usage          Type ST Offset   Length
I (59) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (66) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (74) boot:  2 factory          factory app      00 00 00010000 00100000
I (81) boot: End of partition table
I (85) esp_image: segment 0: paddr=00010020 vaddr=3f000020 size=1f438h (128056) map
I (121) esp_image: segment 1: paddr=0002f460 vaddr=3ffc82c0 size=00bb8h (  3000) load
I (122) esp_image: segment 2: paddr=00030020 vaddr=40080020 size=735fch (472572) map
I (229) esp_image: segment 3: paddr=000a3624 vaddr=3ffc8e78 size=02940h ( 10560) load
I (231) esp_image: segment 4: paddr=000a5f6c vaddr=40022000 size=162b8h ( 90808) load
I (258) esp_image: segment 5: paddr=000bc22c vaddr=50000000 size=00010h (    16) load
I (270) boot: Loaded app from partition at offset 0x10000
I (271) boot: Disabling RNG early entropy source...
I (282) cache: Instruction cache        : size 8KB, 4Ways, cache line size 32Byte
I (282) cpu_start: Pro cpu up.
I (303) cpu_start: Pro cpu start user code
I (303) cpu_start: cpu freq: 240000000
I (304) cpu_start: Application information:
I (306) cpu_start: Project name:     dsr
I (311) cpu_start: App version:      v4.4-dev-1254-g639e7ad49-dirty
I (318) cpu_start: Compile time:     Sep 22 2021 16:12:24
I (324) cpu_start: ELF file SHA256:  86660b37867889e0...
I (330) cpu_start: ESP-IDF:          v4.4-dev-1254-g639e7ad49-dirty
I (337) heap_init: Initializing. RAM available for dynamic allocation:
I (344) heap_init: At 3FF9E000 len 00002000 (8 KiB): RTCRAM
I (350) heap_init: At 3FFD12F0 len 0002AD10 (171 KiB): DRAM
I (357) heap_init: At 3FFFC000 len 00003A10 (14 KiB): DRAM
I (363) spi_flash: detected chip: generic
I (367) spi_flash: flash io: dio
W (371) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
I (396) pm: Frequency switching config: CPU_MAX: 240, APB_MAX: 80, APB_MIN: 40, Light sleep: DISABLED
I (396) cpu_start: Starting scheduler on PRO CPU.
Hello world!
This is esp32s2 chip with 1 CPU cores, WiFi, silicon revision 0, 2MB external flash
Free heap: 179308
esp_clk_cpu_freq: 240000000
esp_clk_apb_freq: ��I (473) wifi:wifi driver task: 3ffd9b10, prio:23, stack:6656, core=0
I (473) system_api: Base MAC address is not set
I (473) system_api: read default base MAC address from EFUSE
I (483) wifi:wifi firmware version: 44799ff
I (483) wifi:wifi certification version: v7.0
I (483) wifi:config NVS flash: enabled
I (483) wifi:config nano formating: disabled
I (493) wifi:Init data frame dynamic rx buffer num: 32
I (493) wifi:Init management frame dynamic rx buffer num: 32
I (503) wifi:Init management short buffer num: 32
I (503) wifi:Init dynamic tx buffer num: 32
I (513) wifi:Init static rx buffer size: 1600
I (513) wifi:Init static rx buffer num: 10
I (513) wifi:Init dynamic rx buffer num: 32
I (523) wifi_init: rx ba win: 6
I (523) wifi_init: tcpip mbox: 32
I (533) wifi_init: udp mbox: 6
I (533) wifi_init: tcp mbox: 6
I (533) wifi_init: tcp tx win: 5744
I (543) wifi_init: tcp rx win: 5744
I (543) wifi_init: tcp mss: 1440
I (553) wifi_init: WiFi IRAM OP enabled
I (553) wifi_init: WiFi RX IRAM OP enabled
I (563) phy_init: phy_version 1800,e7ef680,Apr 13 2021,11:45:08
I (713) wifi:mode : sta (7c:df:a1:00:41:b1)
I (713) wifi:enable tsf
I (713) wifi:set country: cc=JP  schan=1 nchan=14 policy=0
I (713) ESPNOW: espnow [version: 1.0] init
I (713) pm: Frequency switching config: CPU_MAX: 240, APB_MAX: 80, APB_MIN: 10, Light sleep: ENABLED
I (723) wifi:Set ps type: 1
abort() was called at PC 0x400250df on core 0
0x400250df: lock_acquire_generic at C:/Users/Administrator/Desktop/esp-idf/components/newlib/locks.c:138
Backtrace:0x40083063:0x3ffd93900x4002c1ed:0x3ffd93b0 0x40032c6e:0x3ffd93d0 0x400250df:0x3ffd9440 0x40025229:0x3ffd9470 0x400e941a:0x3ffd9490 0x400ec479:0x3ffd97a0 0x400f3601:0x3ffd97d0 0x400316f9:0x3ffd9800 0x400dc2ad:0x3ffd9850 0x400dc2d7:0x3ffd98d0 0x40027daf:0x3ffd9920 0x40028f7d:0x3ffd9990 0x40094c30:0x3ffd99b0 0x40032b55:0x3ffd99d0 0x400c7fb1:0x3ffd99f0 0x400c7fd6:0x3ffd9a10 0x400c8238:0x3ffd9a30 0x400c8a5b:0x3ffd9a50 0x400caa09:0x3ffd9a70 0x400f1f8d:0x3ffd9a90 0x400345de:0x3ffd9ab0 0x4002ec09:0x3ffd9ae0
0x40083063: panic_abort at C:/Users/Administrator/Desktop/esp-idf/components/esp_system/panic.c:379
0x4002c1ed: esp_system_abort at C:/Users/Administrator/Desktop/esp-idf/components/esp_system/esp_system.c:126
0x40032c6e: abort at C:/Users/Administrator/Desktop/esp-idf/components/newlib/abort.c:46
0x40025229: _lock_acquire_recursive at C:/Users/Administrator/Desktop/esp-idf/components/newlib/locks.c:166
0x400e941a: _vfprintf_r at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32s2-elf/src/newlib/newlib/libc/stdio/vfprintf.c:853 (discriminator 2)
0x400ec479: vprintf at /builds/idf/crosstool-NG/.build/HOST-x86_64-w64-mingw32/xtensa-esp32s2-elf/src/newlib/newlib/libc/stdio/vprintf.c:34 (discriminator 5)
0x400f3601: esp_log_writev at C:/Users/Administrator/Desktop/esp-idf/components/log/log.c:181
0x400316f9: esp_log_write at C:/Users/Administrator/Desktop/esp-idf/components/log/log.c:191
0x400dc2ad: lib_printf at C:/Users/Administrator/Desktop/esp-idf/components/esp_wifi/src/lib_printf.c:47 (discriminator 13)
0x400dc2d7: phy_printf at C:/Users/Administrator/Desktop/esp-idf/components/esp_wifi/src/lib_printf.c:57
0x40027daf: phy_i2c_init1 at ??:?
0x40028f7d: phy_wakeup_init at ??:?
0x40094c30: esp_phy_enable at C:/Users/Administrator/Desktop/esp-idf/components/esp_wifi/src/phy_init.c:240
0x40032b55: wifi_rf_phy_enable at ??:?
0x400c7fb1: lmac_stop_hw_txq at ??:?
0x400c7fd6: lmac_stop_hw_txq at ??:?
0x400c8238: pm_update_by_connectionless_status at ??:?
0x400c8a5b: pm_connectionless_wake_interval_timeout_process at ??:?
0x400caa09: dbg_lmac_ps_statis_reset at ??:?
0x400f1f8d: pp_timer_do_process at ??:?
0x400345de: ppTask at ??:?
0x4002ec09: vPortTaskWrapper at C:/Users/Administrator/Desktop/esp-idf/components/freertos/port/xtensa/port.c:168
