打印:
I (182) opi psram: vendor id : 0x0d (AP)
I (182) opi psram: dev id : 0x02 (generation 3)
I (182) opi psram: density : 0x03 (64 Mbit)
I (186) opi psram: good-die : 0x01 (Pass)
I (191) opi psram: Latency : 0x01 (Fixed)
I (196) opi psram: VCC : 0x01 (3V)
I (200) opi psram: SRF : 0x01 (Fast Refresh)
I (206) opi psram: BurstType : 0x01 (Hybrid Wrap)
I (211) opi psram: BurstLen : 0x01 (32 Byte)
I (216) opi psram: Readlatency : 0x02 (10 cycles@Fixed)
I (222) opi psram: DriveStrength: 0x00 (1/1)
I (227) spiram: Found 64MBit SPI RAM device
I (232) spiram: SPI RAM mode: sram 40m
I (236) spiram: PSRAM initialized, cache is in normal (1-core) mode.
I (243) cpu_start: Pro cpu up.
I (247) cpu_start: Starting app cpu, entry point is 0x40375278
0x40375278: call_start_cpu1 at /home/xxxxx/esp/esp-idf/components/esp_system/port/cpu_start.c:156
I (0) cpu_start: App cpu up.
I (985) spiram: SPI SRAM memory test OK
W (985) rtcinit: calibration efuse version does not match, set default version: 0
esp32-s3 启用psram报错
Re: esp32-s3 启用psram报错
I'm getting same error on esp32-s3 IDF 4.4 on a random basis
I (981) spiram: SPI SRAM memory test OK
W (981) rtcinit: calibration efuse version does not match, set default version: 0
Users browsing this forum: No registered users and 24 guests
