windows下idf-tools安装进行到 “Switching branch”时失败
安装时选择的版本为4.2
4.3版本可以正常安装
- 失败.png (19.53 KiB) Viewed 5567 times
- Setup Log 2021-08-30 #001.txt
- (9.5 MiB) Downloaded 430 times
Re: windows下idf-tools安装进行到 “Switching branch”时失败
如果你能直接告知是离线安装,就更好了,从 log 中获取了此信息。
试了下确实有此问题,会反馈到内部。
试了下确实有此问题,会反馈到内部。
- Contact:
Thank you changyue for reporting the issue. We will investigate the problem.
Suggested possible workarounds:
- use Online installer to deploy 4.2.2 - https://dl.espressif.com/dl/esp-idf/
- use Offline installer, deploy 4.3, then open terminal and switch to branch manually:
git checkout v4.2.2
install.bat
export.bat
- Juraj Michálek
Senior Embedded Software Engineer at Espressif Systems
- Contact:
Unfortunately we were not able to simulate the error.
Please, provide output of command:
The output could help us with diagnostics of the problem.
git config --list --show-origin
- Juraj Michálek
- Contact:
Meanwhile we identified the problem.
If the git does not have autocrlf set to true in global config the installation fails.
To workaround the problem it's possible to enter command:
After this correction the installation works without problem.
The new issue for this bug was created: https://github.com/espressif/idf-installer/issues/52
git config --global core.autocrlf true
- Juraj Michálek
- Contact:
We updated Offline installer, please test the following version:
https://github.com/espressif/idf-instal ... 11-beta-02
The installation of 4.2.2 should pass without problem.
- Juraj Michálek
Users browsing this forum: No registered users and 28 guests
