开始折腾自定义at的工程,通过powershall按照给的guide去执行每一步,
https://docs.espressif.com/projects/esp ... le_it.html
clone和build看起来都正常,能下载全所需的组件,但每次想要build执行python build.py menuconfig总是报如下错误。
请教下这个是什么原因导致的,代码没有修改,都是直接clone下来的。
CMake Error at esp-idf/tools/cmake/build.cmake:519 (message):
ERROR: Cannot establish a connection to the component registry. Are you
connected to the internet?
URL:
https://components-file.espressif.com/c ... lient.json
esp-idf/tools/cmake/project.cmake:530 (idf_build_process)
CMakeLists.txt:123 (project)
See also "C:/Espressif/frameworks/esp-at/build/CMakeFiles/CMakeOutput.log".
cmake failed with exit code 1
A fatal error occurred: idf.py build failed
//////////尝试build报错为
PS C:\Espressif\frameworks\esp-at> idf.py build
Executing action: all (aliases: build)
Running cmake in directory C:\Espressif\frameworks\esp-at\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DPYTHON=C:\Espressif\python_env\idf5.2_py3.11_env\Scripts\python.exe -DESP_PLATFORM=1 -DCCACHE_ENABLE=1 C:\Espressif\frameworks\esp-at"...
CMake Error at CMakeLists.txt:9 (string):
string no output variable specified
CMake Error at CMakeLists.txt:10 (string):
string sub-command STRIP requires two arguments.
CMake Error at CMakeLists.txt:14 (string):
string begin index: 9 is out of range 0 - 0
CMake Error at CMakeLists.txt:15 (string):
CMake Error at CMakeLists.txt:16 (string):
-- silence:0, sdkconfig:C:/Espressif/frameworks/esp-at/module_config/module__default/sdkconfig.defaults
-- partition_table_dir: C:/Espressif/frameworks/esp-at
esp-at branch: master
esp-at docs version: latest
no extra component dirs
-- IDF_TARGET not set, using default target: esp32
CMake Warning at esp-idf/tools/cmake/idf.cmake:18 (message):
IDF_PATH environment variable is different from inferred IDF_PATH.
Check if your project's top-level CMakeLists.txt includes the right
CMake files. Environment IDF_PATH will be used for the build:
C:/Espressif/frameworks/esp-idf-v5.2.2
esp-idf/tools/cmake/project.cmake:12 (include)
CMakeLists.txt:121 (include)
-- Found Git: C:/Espressif/tools/idf-git/2.44.0/cmd/git.exe (found version "2.44.0.windows.1")
CMake Error at esp-idf/tools/cmake/idf.cmake:50 (include):
include could not find requested file:
uf2
-- Component directory C:/Espressif/frameworks/esp-at/components/fs_image does not contain a CMakeLists.txt file. No component will be added
-- ccache will be used for faster recompilation
-- The C compiler identification is GNU 13.2.0
-- The CXX compiler identification is GNU 13.2.0
-- The ASM compiler identification is GNU
-- Found assembler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/Espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
CMake Error at esp-idf/tools/cmake/project.cmake:506 (message):
SDKCONFIG_DEFAULTS
'C:/Espressif/frameworks/esp-at/module_config/module__default/sdkconfig.defaults'
does not exist.
cmake failed with exit code 1, output of the command is in the C:\Espressif\frameworks\esp-at\build\log\idf_py_stderr_output_20268 and C:\Espressif\frameworks\esp-at\build\log\idf_py_stdout_output_20268
本地编译at工程失败
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: Google [Bot] and 208 guests
- All times are UTC
- Top
- Delete cookies
About Us
