2024-06-24 18:57:07 SSID : 1908A
2024-06-24 18:57:07 Password : GXFC2021
2024-06-24 18:57:11 I (29083) wifi:primary chan differ, old=1, new=11, start CSA timer
2024-06-24 18:57:11 I (29483) wifi:switch to channel 11
2024-06-24 18:57:11 I (29483) wifi:ap channel adjust o:1,0 n:11,0
2024-06-24 18:57:11 I (29483) wifi<11,0>, old:<1,0>, ap:<11,0>, sta:<0,0>, prof:1
2024-06-24 18:57:11 I (29483) wifi<11,0>, old:<11,0>, ap:<11,0>, sta:<11,0>, prof:1
2024-06-24 18:57:11 I (29803) wifi:state: init -> auth (b0)
2024-06-24 18:57:11 I (29803) wifi:state: auth -> assoc (0)
2024-06-24 18:57:11 I (29813) wifi:state: assoc -> run (10)
2024-06-24 18:57:12 I (29903) wifi:connected with 1908A, aid = 23, channel 11, BW20, bssid = 48:81:d4:6a:e9:fc
2024-06-24 18:57:12 I (29903) wifi:security: WPA2-PSK, phy: bgn, rssi: -57
2024-06-24 18:57:12 I (29923) wifi:pm start, type: 1
2024-06-24 18:57:12
2024-06-24 18:57:12 I (29923) wifi:set rx beacon pti, rx_bcn_pti: 0, bcn_timeout: 25000, mt_pti: 0, mt_time: 10000
2024-06-24 18:57:12 I (29923) wifi_provisioning_test: WIFI_EVENT_STA_CONNECTED
2024-06-24 18:57:12 I (29933) wifi:AP's beacon interval = 102400 us, DTIM period = 1
日志会在这里卡住 应该是获取不到ip 标志位无法变更
使用蓝牙配网则不会出现这种问题 要如何解决
[已解决]使用SoatAP配网 获取不到ip
Re: [求助] 使用SoatAP配网 获取不到ip
没有调用DNS解析吧,如果调用了都不行,那就是你路由器本身有冲突
解决了 是esp32c2 的晶振没有在menuconfig中更改为26
Users browsing this forum: No registered users and 34 guests
