在升级esp-idf到v5.1.1之前,用的是v5.0版本对rainmaker进行编译,能正常运行起来,也能在App上正常添加。
但是升级到v5.1.1之后,再进行编译下载运行之后,出现了以下报错:
E (677718) Dynamic Impl: mbedtls_ssl_fetch_input error=76
E (677718) esp-tls-mbedtls: read error :-0x004C:
E (677718) transport_base: esp_tls_conn_read error, errno=Socket is not connected
E (677728) mqtt_client: esp_mqtt_handle_transport_read_error: transport_read() error: errno=128
E (677738) esp_mqtt_glue: MQTT_EVENT_ERROR
E (677738) mqtt_client: esp_mqtt_connect: mqtt_message_receive() returned -1
E (677748) mqtt_client: MQTT connect failed
W (677748) esp_mqtt_glue: MQTT Disconnected. Will try reconnecting in a while...
然后app就无法连接,在Rainmaker的App中添加设备后,显示了:
X: Confirming Node association
Failed to confirm node association
后来跟踪发现,这个mqtt访问的是亚马逊的Iot网址,应该是被“墙”了,
请问这个问题应该怎么解决?是新版本的esp-idf的问题吗?
关于esp-idf v5.1.1 编译下载esp-rainmaker的example的问题
Users browsing this forum: No registered users and 28 guests
