I am quite knew with ESP32 and i am coding on arduino IDE. Is it possible for me to use the esp-iot-solution library?
Thank you!
ESP IoT solution library in arduino IDE
Re: ESP IoT solution library in arduino IDE
I think you can try using arduino as a component in esp-idf.
https://github.com/espressif/arduino-es ... mponent.md
Thank you costaud! I will give it a try!
