Hello
I use Launcpad web portal to flash Matter applications like allclusterapps into ESP32. Then I use the generated QR code to pair the device. After a few seconds the mobile app shows "Commissioning Failed! Could not pair device. time out"
My phone's Bluetooth is on and all permissions enabled.
This is the tail of console dump :
I (32807) NimBLE: GAP procedure initiated: advertise;
I (32817) NimBLE: disc_mode=2
I (32817) NimBLE: adv_channel_map=0 own_addr_type=2 adv_filter_policy=0 adv_itvl_min=800 adv_itvl_max=800
I (32837) NimBLE:
I (94927) chip[DL]: BLE GAP connection established (con 0)
I (94927) chip[DL]: CHIPoBLE advertising stopped
I (94927) app-devicecallbacks: Current free heap: 89048
I (95737) chip[DL]: BLE GAP connection terminated (con 0 reason 0x213)
I (95737) chip[DL]: Configuring CHIPoBLE advertising (interval 25 ms, connectable, device name MATTER-3840)
I (95757) NimBLE: GAP procedure initiated: advertise;
I (95757) NimBLE: disc_mode=2
I (95757) NimBLE: adv_channel_map=0 own_addr_type=2 adv_filter_policy=0 adv_itvl_min=40 adv_itvl_max=40
I (95767) NimBLE:
I (95777) chip[DL]: CHIPoBLE advertising started
I (95777) app-devicecallbacks: CHIPoBLE disconnected
I (95787) app-devicecallbacks: Current free heap: 89048
Any idea what can be wrong?
Matter application is stuck in pairing stage using Launchpad
- 5041.jpg (1.06 MiB) Viewed 5008 times
Re: Matter application is stuck in pairing stage using Launchpad
Hi, I have the same problem. Did you figure out how to get it to work?
I'm having this issue as well
Users browsing this forum: No registered users and 10 guests
