Heap Issue in MWiFi Library
Posted: Fri Jan 21, 2022 9:36 am
Good day !
Hardware details: Thing Plus C - ESP32 WROOM (https://www.sparkfun.com/products/18018).
Framework: ESP-MDF (ESP-IDF v4.2.0).
Scenario:
We are using ESP-MDF for WiFi mesh network with router-based. The root node gets files from the server using protocol and sends it to the requested node in mesh network using "Mwifi_write".
When it's continuously sending files to the nodes using Mwifi_write, the heap is gradually getting filled (when the Mwifi_write is hit, the heap is getting gradually filled).
We have fully cleared(free) all the allocated memory. And we found that heap issue is in "MWifi" library("Mwifi_write").
Question:
Does "Mwifi"/"Mwifi_write" library has heap leak/issues?
Thanks for the answers
Regards,
Rajkumar
Good day !
Scenario:
Question:
Regards,
Rajkumar
