Hello.
For my solution i need to connect to mesh nodes by IP.
I know that nodes communicate via MAC address tables.
But i need to connect end point device (not part of the mesh network) to node of my choice to control.
Device, it is a tablet, had an ip and connected to wifi network.
Is it theoretically possible to make every node also a dns server and tcp server? And mesh leave as a transport?
I know it is not possible with default setup using github sources.
But how do you think, is it possible to add such things?
Mesh network with ip connectivity to nodes
Re: Mesh network with ip connectivity to nodes
espressif guys you will never win with such poor support to developers, most of the topics at forum is dropped at some stage or just unanswered.
What a shame
What a shame
- Contact:
Assuming that your actual goal is to address individual devices, if you use something like MQTT or OSC which use URL-style messages, you can include the desired mesh address as the first term of the URL. Your root node should strip this value from the start of the message and use it to send a message to mwifi_write().
Send a message to a specific node
Send a message to all nodes
Send a message to all nodes of multiple mesh networks
Send to root with IP: 192.168.0.10
/aa:bb:cc:dd:ee:ff/{rest_of_command}
/ff:ff:ff:ff:ff:ff/{rest_of_command}
Send to root with IP: 255.255.255.255
- Contact:
You know this is wonderfully ironic looking back
Users browsing this forum: No registered users and 13 guests
