Issues while trying to add a custom board
Posted: Mon Dec 09, 2024 7:24 pm
by AndreaS73
Ubuntu 24.10, with ESP-IDF 5.3.0 and ESP-ADF from branch `master`.
Here are the steps I followed:
1. installed VSCode and ESP-IDF extension and ESP-ADF framework
2. created a new project based upon the example template `esp-adf/examples/player/pipeline_a2dp_source_stream`
3. compiled and check there are no errors (I didn't change anything from the original sample code)
4. now I want to switch from the default dev board to my custom one, so in the SDK options I set Audio HAL > Audio board > Custom auido board
5. in my source tree, I created a `components/myboard`
6. copied all the files from `esp-adf/components/audio_board/lyrat_v4_3/` to the above directory
7. added `CMakeLists.txt` and `component.mk` (see below)
8. adjusted my project's `CMakeLists.txt`, clean and build
Project tree:
    $ tree . -L 3
    ├── build [cutted]
    ├── CMakeLists.txt
    ├── components
    │   └── myboard
    │       ├── board.c
    │       ├── board_def.h
    │       ├── board.h
    │       ├── board_pins_config.c
    │       ├── board_pins_config.h
    │       ├── CMakeLists.txt
    │       └── component.mk
    ├── dependencies.lock
    ├── main
    │   ├── component.mk
    │   ├── Kconfig.projbuild
    │   └── main.c
    ├── Makefile
    ├── managed_components [cutted]
    ├── partitions_bt_source_example.csv
    ├── sdkconfig
    ├── sdkconfig.defaults
    ├── sdkconfig.defaults.esp32
    └── sdkconfig.old
and here is the content of the relevant files:
**Project CMakeLists.txt**
    cmake_minimum_required(VERSION 3.5)
    set(EXTRA_COMPONENT_DIRS components)
    include($ENV{ADF_PATH}/CMakeLists.txt)
    include($ENV{IDF_PATH}/tools/cmake/project.cmake)
    project(myproject)
**main CMakeLists.txt**
   set(COMPONENT_SRCS "main.c")
    set(COMPONENT_ADD_INCLUDEDIRS . ../components)
    set(COMPONENT_REQUIRES audio_hal audio_board myboard audio_pipeline)
    set(COMPONENT_PRIV_REQUIRES )
    register_component()
**myboard CMakeLists.txt**
  set(COMPONENT_REQUIRES)
    set(COMPONENT_PRIV_REQUIRES audio_sal audio_hal esp_dispatcher esp_peripherals)
    if (CONFIG_AUDIO_BOARD_CUSTOM)
    message(STATUS "Current board name is " MyBoard)
    list(APPEND COMPONENT_ADD_INCLUDEDIRS .)
    set(COMPONENT_SRCS "board.c" "board_pins_config.c")
    endif()
**myboard component.mk**
    ifdef CONFIG_AUDIO_BOARD_CUSTOM
    COMPONENT_ADD_INCLUDEDIRS += .
    COMPONENT_SRCDIRS += .
    endif
When I compiled it fails, returning a lot of errors like this:
    /home/mark/dev/esp/esp-adf/components/audio_hal/driver/zl38063/api_lib/vproc_common.c:19:10: fatal error: board.h: No such file or directory
       19 | #include "board.h"
One for each driver being compiled, where `board.h` should be the one under `myboard` directory.
I thougth I properly added the include directives, but surely I'm missing something.
What I should add in those files in order the internal library can find the new `board.h` file?
Re: Issues while trying to add a custom board
Posted: Wed Feb 05, 2025 6:35 pm
by ruben.crispino
Hello, not sure if you have solved it already, but for future reference, I am going to share my results since I had the same issue recently.
First, the components directory is already scanned by Cmake, so we do not need to add
into the Project CMakeLists.txt.
I recently added a custom board into my project and my Project CMakeList.txt looks like this:
# The following lines of boilerplate have to be in your project's
# CMakeLists in this exact order for cmake to work correctly
project(app_name)
Same thing for the main CMakeLists.txt -> this is untouched.
The only necessary thing is the Cmake.txt inside the components directory. Mine looks like this:
set(COMPONENT_ADD_INCLUDEDIRS ./include)
# Edit following two lines to set component requirements (see docs)
set(COMPONENT_REQUIRES )
set(COMPONENT_PRIV_REQUIRES esp_peripherals audio_sal audio_hal esp_dispatcher display_service)
message(STATUS "Current board name is " CONFIG_AUDIO_BOARD_CUSTOM)
list(APPEND COMPONENT_ADD_INCLUDEDIRS ./board_folder)
set(COMPONENT_SRCS
./board_folder/board.c
./board_folder/board_pins_config.c
endif()
