Question on ADF's i2s_stream_cfg_t i2s_stream.h -- what is "buffer_len"?
This question is just out of pure curiosity and to know how the code I'm using actually works. I had some code that used an older version of ADF (I believe 2.3 or so), which would use ADF's i2s_stream (esp-adf/components/audio_stream/include/i2s_stream.h). When updating ADF to the current version in master branch, some of my code broke, and after wandering around in the source, I found that the new version had an extra element in the structure i2s_stream_cfg_t "buffer_len", which if I did not initilaized, the audio would just not run (the code would all run without a problem or errors, but the audio would just not work -- and all the warning I would get is "AUDIO_THREAD: Make sure selected the `CONFIG_SPIRAM_BOOT_INIT` and `CONFIG_SPIRAM_ALLOW_STACK_EXTERNAL_MEMORY` by `make menuconfig", which I get anyway even when the audio runs by setting buffer_len to 3600). Thankfully, it all was fixed just by adding that extra line setting .buffer_len = 3600. However, I don't think the documentation is clear as to what this parameter is exactly. Is it related to the ringbuffer used to connect the distinct elements? If so, isn't the rinbuffer size determined by the other parameters (out_rb_size, task_stack, etc)? If not so, what is this buffer used for? Why was it added to the i2s_stream_cfg_t structure?
Re: Question on ADF's i2s_stream_cfg_t i2s_stream.h -- what is "buffer_len"?
Buffer_len is added to fix the issue when play 24bits, the buffer needs sample aligned, if use 1024 it will have issue.
It is added recently and initialized using I2S_STREAM_CFG_DEFAULT()
If your example do not not the macro to do the initialization and assign value manually. It will have issue.
Users browsing this forum: No registered users and 12 guests
