Running equalizer together with mp3 decoding
Posted: Wed Nov 02, 2022 1:36 am
I have a pipeline running that reads from an sdcard and decodes mp3 files before sending out i2s to a classd amp. I tried putting the equalizer element in the pipeline to give me the ability to reduce bass (our simple speaker hardware distorts with too much bass). I followed the equalizer example code. Unfortunately, with the default equalizer gains (which should do very little as it is flat) the output sounds terrible at any volume. It sounds slightly laggy and distorted. Every now and then I see...
... in the log. So it looks as though the processor is not keeping up with the work load. Is the equaliser that thirsty on the cpu? There is no source code for it, so it is hard to tell if it has been optimised. Could there be some other reason for this problem? If I can not use the equaliser to reduce bass, what other options do I have? Is there a simple bass/treble filter element that would be lighter weight on the cpu?
Thanks in advance!
E (1434316) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (1434316) task_wdt: - IDLE (CPU 0)
E (1434316) task_wdt: Tasks currently running:
E (1434316) task_wdt: CPU 0: mp3
E (1434316) task_wdt: CPU 1: IDLE
Thanks in advance!
