How to make two parallel pipelines
Posted: Thu Jun 10, 2021 3:24 pm
by spacebiker
There is an example of parallel pipelines: https://github.com/espressif/esp-adf/bl ... _to_file.c
I need to do the same thing, but bluetooth instead of http.
So I have two pipelines: bt -> i2s and raw -> wav_encoder -> fatfs
So i init all pipelines:
    i2s_stream_cfg_t i2s_cfg1 = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg1.type = AUDIO_STREAM_WRITER;
    i2s_stream_writer = i2s_stream_init(&i2s_cfg1);
    i2s_stream_cfg_t i2s_cfg2 = I2S_STREAM_CFG_DEFAULT();
    i2s_cfg2.type = AUDIO_STREAM_READER;
    i2s_stream_reader = i2s_stream_init(&i2s_cfg2);
    raw_stream_cfg_t raw_cfg = RAW_STREAM_CFG_DEFAULT();
    raw_cfg.type = AUDIO_STREAM_READER;
    raw_read = raw_stream_init(&raw_cfg);
    bt_stream_reader = bluetooth_service_create_stream();
    audio_pipeline_register(pipeline_bluetooth_i2sw, bt_stream_reader, "bt");
    audio_pipeline_register(pipeline_bluetooth_i2sw, i2s_stream_writer, "i2s_w");
    audio_pipeline_register(pipeline_i2sr_raw, i2s_stream_reader, "i2s_r");
    audio_pipeline_register(pipeline_i2sr_raw, raw_read, "raw");
    const char *link_d[2] = {"bt", "i2s_w"};
    audio_pipeline_link(pipeline_bluetooth_i2sw, &link_d[0], 2);
    const char *link_e[2] = {"i2s_r", "raw"};
    audio_pipeline_link(pipeline_i2sr_raw, &link_e[0], 2);
    fatfs_stream_cfg_t fatfs_write_cfg = FATFS_STREAM_CFG_DEFAULT();
    fatfs_write_cfg.type = AUDIO_STREAM_WRITER;
    fatfs_stream_writer = fatfs_stream_init(&fatfs_write_cfg);
    raw_cfg.type = AUDIO_STREAM_WRITER;
    el_raw_read = raw_stream_init(&raw_cfg);
    wav_encoder_cfg_t wav_cfg = DEFAULT_WAV_ENCODER_CONFIG();
    wav_encoder = wav_encoder_init(&wav_cfg);
    audio_pipeline_cfg_t  pipeline_for_record_cfg = DEFAULT_AUDIO_PIPELINE_CONFIG();
    pipeline_for_record = audio_pipeline_init(&pipeline_for_record_cfg);
    audio_element_set_uri(fatfs_stream_writer, "/sdcard/rec2.wav");
    audio_pipeline_register(pipeline_for_record, el_raw_read, "raw");
    audio_pipeline_register(pipeline_for_record, wav_encoder, "wav");
    audio_pipeline_register(pipeline_for_record, fatfs_stream_writer, "file");
    const char *link_tag[3] = {"raw", "wav", "file"};
    audio_pipeline_link(pipeline_for_record, &link_tag[0], 3);
And I made ring buffer connected to bt_stream_reader:
ringbuf_handle_t rb = audio_element_get_output_ringbuf(el_raw_read);
audio_element_set_multi_output_ringbuf(bt_stream_reader, rb, 0);
and trying to save audio data on sd card. But every time I play music I get 44 bytes .wav file full of 0x00.
What am I doing wrong? Thank you
Full code is here: https://pastebin.com/bg0HVhUe
