Memory allocation problem WroverB ADF
Posted: Fri Apr 17, 2020 5:37 am
I'm writing an application in ESP-ADF.
My board is TTGO Wrover B connected via ESP Prog.
All works well till yesterday, and i am not able to getting it working again.
In Initialisation there seems to be a memory Problem. audio_pipeline_init runs in the "memory exhaust" error:
Debugger says that it should allocate the Memory with this code in audio_mem.c, nmemb=1 and size = 32
I do not know, if it has something to do with:
Programming without Jtag over serial with make Flash has also error, also with ALL devices DISCONNECTED
make size shows:
Pleas help me finding a solution for this Problem.
player->pipeline = audio_pipeline_init(&pipeline_cfg);
if (player->pipeline == NULL)
ESP_LOGE(TAG, "Error creating audio Pipeline");
return NULL ;
data = heap_caps_malloc(nmemb * size, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT);
App "play_and_save" version: 1
Flashing binaries to serial port /dev/ttyUSB0 (app at offset 0x10000)...
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP32D0WDQ5 (revision 1)
Crystal is 40MHz
MAC: b4:e6:2d:de:90:19
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
A fatal error occurred: Timed out waiting for packet header
Total sizes:
DRAM .data size: 14016 bytes
DRAM .bss size: 25680 bytes
Used static DRAM: 39696 bytes ( 141040 available, 22.0% used)
Used static IRAM: 98025 bytes ( 33047 available, 74.8% used)
Flash code: 630501 bytes
Flash rodata: 164904 bytes
Total image size:~ 907446 bytes (.bin may be padded larger)
