Audio board init with ESP32-WROVER_IB (16MB)
Posted: Fri Mar 20, 2020 11:38 am
Hello
In our project board we've using module ESP32-WROVER-IB with 16MB of Flash. To reproduce audio our board has the same esquema of the LyraT_v4.3 with some pins changes.
The issue is that the MP3 simple example works perfect buf when I tried to enable external SPI RAM (default conf), it doesn't work.
To add more information, configuration file is attached and the pin changes of our custom board are:
Here is the trace of the problem:
Thanks so much.
HEADPHONE_DETCET GPIO_NUM_16
PA_ENABLE_GPIO GPIO_NUM_17
i2c_config->sda_io_num = GPIO_NUM_32;
i2c_config->scl_io_num = GPIO_NUM_33;
i2s_config->bck_io_num = GPIO_NUM_5;
i2s_config->ws_io_num = GPIO_NUM_25;
i2s_config->data_out_num = GPIO_NUM_26;
i2s_config->data_in_num = GPIO_NUM_35;
And in i2s_mclk_gpio_select function gpio_num is forced to: gpio_num = GPIO_NUM_1;
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6980
load:0x40078000,len:12072
load:0x40080400,len:6908
entry 0x4008079c
I (72) boot: Chip Revision: 1
I (72) boot_comm: chip revision: 1, min. bootloader chip revision: 0
I (39) boot: ESP-IDF v3.3.1-211-g6f9a7264c 2nd stage bootloader
I (39) boot: compile time 12:26:57
I (40) boot: Enabling RNG early entropy source...
I (44) boot: SPI Speed : 40MHz
I (48) boot: SPI Mode : DIO
I (52) boot: SPI Flash Size : 16MB
I (57) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 nvs WiFi data 01 02 00009000 00004000
I (75) boot: 1 otadata OTA data 01 00 0000d000 00002000
I (82) boot: 2 phy_init RF data 01 01 0000f000 00001000
I (90) boot: 3 factory factory app 00 00 00010000 00200000
I (97) boot: End of partition table
I (101) boot: Defaulting to factory image
I (106) boot_comm: chip revision: 1, min. application chip revision: 0
I (113) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2c254 (18
0820) map
I (186) esp_image: segment 1: paddr=0x0003c27c vaddr=0x3ffb0000 size=0x020ac (
8364) load
I (189) esp_image: segment 2: paddr=0x0003e330 vaddr=0x40080000 size=0x00400 (
1024) load
I (193) esp_image: segment 3: paddr=0x0003e738 vaddr=0x40080400 size=0x018d8 (
6360) load
I (204) esp_image: segment 4: paddr=0x00040018 vaddr=0x400d0018 size=0x2a32c (17
2844) map
I (271) esp_image: segment 5: paddr=0x0006a34c vaddr=0x40081cd8 size=0x0d910 ( 5
5568) load
I (303) boot: Loaded app from partition at offset 0x10000
I (303) boot: Disabling RNG early entropy source...
I (304) psram: This chip is ESP32-D0WD
I (310) spiram: Found 64MBit SPI RAM device
I (313) spiram: SPI RAM mode: flash 40m sram 40m
I (318) spiram: PSRAM initialized, cache is in low/high (2-core) mode.
I (326) cpu_start: Pro cpu up.
I (329) cpu_start: Application information:
I (334) cpu_start: Project name: play_mp3
I (339) cpu_start: App version: v2.0-beta3-25-g11b626c-dirty
I (346) cpu_start: Compile time: Mar 20 2020 12:27:01
I (352) cpu_start: ELF file SHA256: 030bab1bcf69d565...
I (358) cpu_start: ESP-IDF: v3.3.1-211-g6f9a7264c
I (364) cpu_start: Starting app cpu, entry point is 0x40081480
I (351) cpu_start: App cpu up.
I (1255) spiram: SPI SRAM memory test OK
I (1256) heap_init: Initializing. RAM available for dynamic allocation:
I (1256) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1262) heap_init: At 3FFB31A8 len 0002CE58 (179 KiB): DRAM
I (1268) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1275) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1281) heap_init: At 4008F5E8 len 00010A18 (66 KiB): IRAM
I (1288) cpu_start: Pro cpu start user code
I (1293) spiram: Adding pool of 4096K of external SPI memory to heap allocator
I (307) cpu_start: Starting scheduler on PRO CPU.
I (309) spiram: Reserving pool of 32K of internal memory for DMA/internal alloca
tions
I (309) PLAY_MP3_FLASH: [ 1 ] Start audio codec chip
I (339) PLAY_MP3_FLASH: [ 2 ] Create audio pipeline, add all elements to pipelin
e, and subscribe pipeline event
I (339) PLAY_MP3_FLASH: [2.1] Create mp3 decoder to decode mp3 file and set cust
om read callback
I (349) PLAY_MP3_FLASH: [2.2] Create i2s stream to write data to codec chip
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandle
d.
Core 0 register dump:
PC : 0x4008efdf PS : 0x00060730 A0 : 0x80084df8 A1 : 0x3f
fb4c30
A2 : 0x3f800000 A3 : 0x000000d0 A4 : 0x00000000 A5 : 0x00
070c80
A6 : 0x00000102 A7 : 0x00000000 A8 : 0x00000000 A9 : 0xff
ffffff
A10 : 0x3f800010 A11 : 0x00060b23 A12 : 0x3f800014 A13 : 0x00
000000
A14 : 0xffffffff A15 : 0x00000000 SAR : 0x00000014 EXCCAUSE: 0x00
00001c
EXCVADDR: 0xffffffff LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00
000000
ELF file SHA256: 030bab1bcf69d565fb644b99ef2d079b4719c4fe72ca85eb1e50b1d08e9faa6
c
Backtrace: 0x4008efdf:0x3ffb4c30 0x40084df5:0x3ffb4c50 0x400ea3a4:0x3ffb4c70 0x4
00e9215:0x3ffb4c90 0x400eaa24:0x3ffb4d20 0x400d64b6:0x3ffb4de0 0x400d17e4:0x3ffb
4ef0 0x4008c1b1:0x3ffb4f10
Rebooting...
