Audio 2 Way Stream with VBAN UDP Protocol
Orizine
Postby Orizine » Fri Dec 24, 2021 12:59 am
Hey here,
i'm new, i'm noob, 2 weeks ago i never code anything, but i've tried to do that, and that WORKss !!! I've use many project i could fine on github to do it, merge it as i can, and now i try to add some options, like control the volume, or send command from the webserial or VBAN Text protocol. Also the OTA I'm not arrived to make work :D
So, i put that here https://github.com/Orizine/ESP32-VBAN-2-WAY
What i use :
https://forum.raspiaudio.com/t/muse-proto-board/231
https://www.gotronic.fr/art-module-micr ... -22179.htm
That work not perfectly, some random crash i'm not able to identify, near sure i'm not use the memory as good as the board can. maybe some memory loss.
Maybe also, I2S_Stream could work?
So, i really don't know what i could do to make that better, really many thing are not "pro"... but actually that work, and if you have some tips or advice, pro option to make that better. I will be happy to read that and continue to learn how i can do better :D
Thanks :D
Users browsing this forum: No registered users and 23 guests
