I am having problems with the audio quality of the bluetooth HFP.
Hardware: ESP32_LyraT V4.3
Software: esp-idf V3.3, esp-adf v2.0-beta2-24-g40cb926
Example project: \esp-adf\examples\get-started\pipeline_a2dp_sink_and_hfp (unmodified)
I built the pipeline_a2dp_sink_and_hfp project, and flashed it to the ESP32_LyraT board. I got my iPhone paired with ESP32.
I ran the Echo/Sound test service of Skype on the iPhone. The Skype’s automated voices were transferred to and played by the LyraT board via the bluetooth HFP. The voices had cracking noises, and I had a bunch of warning messages:
W (90978) BT_BTM: SCO xmit Q overflow, pkt dropped
W (90978) BT_BTM: stat 10
Then, I talked to the microphone of the ESP32_LyraT board. Skype echoed back my voices, which were having large harsh noises and barely audible. I tried with an external microphone plugged in the LyraT board, but had the same results. My iPhone works OK with the AirPods.
Are there any clues to solving these problems?
Oba
Noises of the Bluetooth HFP running on ESP32_LyraT board
Re: Noises of the Bluetooth HFP running on ESP32_LyraT board
I'm also running into this issue. I'm using the esp-adf/examples/get-started/pipeline_a2dp_sink_and_hfp code. The module sinks audio just fine over A2DP and HFP, however when it sources audio there is just silence and the following is printed to the console every 20 milliseconds.
W (50017) BT_BTM: SCO xmit Q overflow, pkt dropped
W (50017) BT_BTM: stat 10
W (50037) BT_BTM: SCO xmit Q overflow, pkt dropped
W (50037) BT_BTM: stat 10
Hi all
I am also running the ad2p_sink_and_hfp example. I have the impression that the audio quality is better from the phone to the ESP32 than from the ESP32 to the phone.
I took a look in esp-idf/components/bt/host/bluedroid/stack/btm/btm_sco.c and I added some logs in the BTM_WriteScoData function:
- Just before
I print p_buf->len. the value is always 60.
- Just before
I print fixed_queue_length(p_ccb->xmit_data_q). The values are series starting from 14, 16 or 18, and ending to 20, then the " SCO xmit Q overflow, pkt dropped" message is shown. For example: 14, 15, .., 20, warning, 16, 17, .., 20, warning, and so on.
The current define values are the following:
- BTM_SCO_DATA_SIZE_MAX = 120
- BTM_SCO_XMIT_QUEUE_THRS = 20
I also notice that the mSBC codec is being used:
Many thanks in advance
Bonel
- Just before
if (p_buf->len > BTM_SCO_DATA_SIZE_MAX)
- Just before
if (fixed_queue_length(p_ccb->xmit_data_q) < BTM_SCO_XMIT_QUEUE_THRS)
Could this problem be specific to the TX path, as the audio from the phone to the ESP32 (RX) seems to be correct? Do you have any ideas or suggestions?I (15677) MyProject: bt_app_hf_client_audio_open
I (15687) MyProject: hf open msbc
W (15697) BT_APPL: new conn_srvc id:19, app_id:0
E (15697) BT_APPL: bta_dm_pm_btm_status hci_status=32
I (15697) I2S: APLL: Req RATE: 16000, real rate: 15999.986, BITS: 16, CLKM: 1, BCK_M: 8, MCLK: 4095996.500, SCLK: 511999.562500, diva: 1, divb: 0
Bonel
Hi guys,
Did you find any solution to this problem??
im really having audio quality issues over this.
Thank-You
Tarun Narain
Thank-You
Tarun Narain
Hi
The above phenomenon should be packet loss caused by the coexistence problem. I have a suggestion that you could test it:
Switch ADF to the latest master, and IDF uses Release4 4.
Then use this demo to test A2DP and HFP functions:
https://github.com/espressif/esp-adf/tr ... t_ble_coex
