Hi!!!
I'm new to the ESP32-LyraTD-MSC_A V2.2 board, currently, I'm trying to run an example of pipeline sonic. I have already run this example on the ESP32-LyraT V4.3 board and its works fine.
Can anyone help me with how to set the pipeline sonic example according to the ESP32-LyraTD-MSC_A V2.2 board?
Unable to run pipeline example on esp32 lyratd msc
Re: Unable to run pipeline example on esp32 lyratd msc
I have found the solution to my problem.
Solution:
If you are using Espressif IDE. There will be a file with the name sdkconfig in your project path. Open this file while using IDE. When the file opens click on Audio HAL. After this, there will be an option for board selection. Select the board which you are using.
Solution:
Users browsing this forum: No registered users and 19 guests
