ESP32 and CR2032 battery
Posted: Sun Jan 15, 2017 11:10 pm
My understanding is that ESP32 should be able to run on CR2032, but I have no success with that. Trying a simple hello_world example works fine with an external 3v power source, but switching to battery a throws the following error:
and then the error reappears in the indefinite loop..
Do you guys have any experience with ESP32 running on a CR2032 or similar (small) battery?
I (65) boot: Partition Table:
I (71) boot: ## Label Usage Type ST Offset Length
I (82) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (93) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (104) boot: 2 factory factory app 00 00 00010000 00100000
I (116) boot: End of partition table
I (122) boot: Loading app partition at offset 00010000
I (558) boot: segment 0: paddr=0x00010018 vaddr=0x00000000 size=0x0ffe8 ( 65512)
I (559) boot: segment 1: paddr=0x00020008 vaddr=0x3f400010 size=0x05b20 ( 23328) map
I (567) boot: segment 2: paddr=0x00025b30 vaddr=0x3ffb3140 size=0x02364 ( 9060) load
I (583) boot: segment 3: paddr=0x00027e9c vaddr=0x40080000 size=0x00400 ( 1024) load
I (593) boot: segment 4: paddr=0x000282a4 vaddr=0x40080400 size=0x13814 ( 79892) load
I (644) boot: segment 5: paddr=0x0003bac0 vaddr=0x400c0000 size=0x00000 ( 0) load
I (645) boot: segment 6: paddr=0x0003bac8 vaddr=0x00000000 size=0x04540 ( 17728)
I (652) boot: segment 7: paddr=0x00040010 vaddr=0x400d0018 size=0x20a60 (133728) map
I (665) boot: segment 8: paddr=0x00060a78 vaddr=0x50000000 size=0x00008 ( 8) load
I (679) heap_alloc_caps: Initializing. RAM available for dynamic allocation:
I (689) heap_alloc_caps: At 3FFB54A4 len 0002AB5C (170 KiB): DRAM
I (699) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM
I (710) heap_alloc_caps: At 40093C14 len 0000C3EC (48 KiB): IRAM
I (720) cpu_start: Pro cpu up.
I (726) cpu_start: Starting app cpu, entry point is 0x40080b10
I (0) cpu_start: App cpu up.
I (741) cpu_start: Pro cpu start user code
Guru Meditation Error of type IllegalInstruction occurred on core 0. Exception was unhandled.
Register dump:
PC : 0x400eb0e0 PS : 0x00060f30 A0 : 0x8008093a A1 : 0x3ffe3c10
A2 : 0x00000000 A3 : 0x0c00001c A4 : 0x3ffe3b7f A5 : 0x00000031
A6 : 0x00000000 A7 : 0x3ffe3b84 A8 : 0x800eb19a A9 : 0x00000000
A10 : 0x00000027 A11 : 0x3f405000 A12 : 0x3ff480c8 A13 : 0x00000000
A14 : 0xffffffff A15 : 0x2d580210 SAR : 0x00000004 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0xffffffff
Backtrace: 0x400eb0e0:0x3ffe3c10 0x4008093a:0x3ffe3c30 0x40080ae3:0x3ffe3c60 0x40078365:0x3ffe3ca0 0x4007857c:0x3ffe3cd0 0x40078ab4:0x3ffe3d50 0x40080101:0x3ffe3e70 0x40007c34:0x3ffe3eb0 0x40000740:0x3ffe3f20
Rebooting...
ets Jun 8 2016 00:22:57
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
cmd len 2147483262
Falling back to built-in command interpreter.
OK
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3ffc0008,len:4
load:0xffffffff,len:-1
