MQTT publish via Mongoose
Posted: Thu Jan 05, 2017 9:02 pm
Hey all,
I'm using the following code to try to set up an mqtt connection and publish. As you can see I'm using arduino as a component for the ESP-IDF.
My event handler never receives any events, which started me digging down this path. It looks like there may be a socket issue? But it may be that one issue causes the other... Any help would be appreciated!
When I try to poll for work, I see this:
So I turned on debugging, and the following is the output:
Did some digging and errno 119 for lwip means no XENIX semaphores available.
No idea what that means! I'm pretty sure I want to use MQTT without sockets, but not sure if that is possible with mongoose.
#include <string.h>
#include "Arduino.h"
#include <WiFi.h>
#include "mongoose.h"
#include "esp_spiffs.h"
#include "esp_spiffs.c"
#include "spiffs.h"
#include "spiffs_vfs.h"
#include "esp_vfs.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "esp_system.h"
#include "esp_log.h"
// RTOS stuff
int CONNECTION_CHECK_RATE = 5000;
int DEFAULT_TASK_DELAY = 1000;
int DEFAULT_SMPHR_WAIT = 500;
// connection stuff
const char* ssid = "mywifi";
const char* pass = "mypassword";
bool mqtt_initialized = false;
bool wifi_initialized = false;
const struct mg_mqtt_topic_expression test_topic = { "/variousthings", 1 }; //"{topic, QOS}"
static void mongoose_event_handler( struct mg_connection *nc, int ev, void *evData )
printf("inside event handler\n");
switch( ev )
case MG_EV_CONNECT : printf("MG_EV_CONNECT\n");
break;
case MG_EV_MQTT_CONNACK : printf("MG_EV_MQTT_CONNACK\n");
printf( "we connected" );
// mg_mqtt_subscribe( &mqtt_connection, &test_topic, 1, 42 );
break;
case MG_EV_MQTT_PUBACK : printf("MG_EV_MQTT_PUBACK");
break;
// static const char *s_address = "test.mosquitto.org:1883";
static const char *s_address = "tcp://37.187.106.16:1883";
void init_mongoose()
struct mg_mgr mgr;
mg_mgr_init( &mgr, NULL );
struct mg_connection *mqtt_connection = mg_connect( &mgr, s_address, mongoose_event_handler );
mg_set_protocol_mqtt( mqtt_connection ); // attach built in event handler
if( mqtt_connection != NULL )
printf("mg_connection created successfully\n");
else
printf("mg_connection not created\n");
mg_mqtt_publish( mqtt_connection, "/variousthings", 1, MG_MQTT_QOS(0), "apples", 6 ); // breaks things
mqtt_initialized = true;
* maintains wifi and mqtt connections
void manage_connection_task( void *p )
while( true )
if ( WiFi.status() == WL_CONNECTED && !mqtt_initialized )
printf("initting mongoose\n");
init_mongoose();
else if( WiFi.status() != WL_CONNECTED && !wifi_initialized )
printf("initting wifi\n");
WiFi.begin( ssid, pass );
wifi_initialized = true;
else if ( WiFi.status() == WL_CONNECTED && wifi_initialized && mqtt_initialized )
struct mg_mgr mgr;
mg_mgr_poll( &mgr, 1000 );
//printf("num ifaces: %d\n", mgr.num_ifaces);
vTaskDelay( 250 / portTICK_PERIOD_MS );
int idx = 0;
extern "C" void app_main()
struct timeval time;
gettimeofday( &time, NULL );
printf( "%ld", time.tv_sec );
initArduino();
xTaskCreate( &manage_connection_task,
"manage_connection_task",
2048,
NULL,
5,
NULL );
mg_mgr_poll cannot poll: no interfaces
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3ffc0008,len:0
load:0x3ffc0008,len:1964
load:0x40078000,len:3696
ho 0 tail 12 room 4
load:0x40080000,len:260
entry 0x40080034
I (689) heap_alloc_caps: Initializing heap allocator:
I (689) heap_alloc_caps: Region 19: 3FFC1288 len 0001ED78 tag 0
I (690) heap_alloc_caps: Region 25: 3FFE8000 len 00018000 tag 1
I (701) cpu_start: Pro cpu up.
I (706) cpu_start: Single core mode
I (713) cpu_start: Pro cpu start user code
W (809) cpu_start: failed to load RF calibration data, falling back to full calibration
I (2261) phy: phy_version: 258, Nov 29 2016, 15:51:07, 0, 2
I (2928) cpu_start: Starting scheduler on PRO CPU.
1tcpip_task_hdlxxx : 3ffc4e20, prio:18,stack:2048
I (2937) wifi: frc2_timer_task_hdl:3ffc68d8, prio:22, stack:2048
I (2946) wifi: pp_task_hdl : 3ffc9148, prio:23, stack:8192
initting wifi
I (2948) wifi: mode : softAP (24:0a:c4:00:03:6d)
dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)
I (2958) wifi: mode : sta (24:0a:c4:00:03:6c) + softAP (24:0a:c4:00:03:6d)
I (4589) wifi: ap channel adjust o:1,1 n:11,2
I (4589) wifi: n:11 0, o:1 0, ap:11 2, sta:11 0, prof:1
I (5237) wifi: state: init -> auth (b0)
I (5239) wifi: state: auth -> assoc (0)
I (5247) wifi: state: assoc -> run (10)
I (5356) wifi: connected with JUSTICE, channel 11
I (8039) event: ip: 172.20.10.9, mask: 255.255.255.240, gw: 172.20.10.1
initting mongoose
mg_socket_if_init 0x3ffca490 using select()
mg_mgr_init_opt ==================================
mg_mgr_init_opt init mgr=0x3ffca490
mg_do_connect 0x3ffc30b0 tcp://37.187.106.16:1883
mg_socket_if_connect_tcp 0x3ffc30b0 sock 0 rc -1 errno 119 err 0
mg_add_conn 0x3ffca490 0x3ffc30b0
