HTTP requests (GET, POST etc.) on ESP32
andrew_p
Postby andrew_p » Sun Jan 01, 2017 10:28 pm
I'm playing with code examples provided on esp-idf github and fee like missing something.
As of now I'm mostly interested in POST requests, there are no examples on github, but I was able to modify https example and successfully sent POST message to external server (created a data record on a server), but got a problem: ESP32 doesn't process a response from the server, it just freezes and no log messages fired. And if I comment the part of the code, which processes the response, no issues appeared. Can somebody help with this or just provide a correct example how to send POST requests?
This is my POST request:
POST https://xxxx.xxxx.com/xx/xxxxx HTTP/1.1
Host: xxxx.xxxx.com
Accept: application/json
Content-Type: application/json
Authorization: Basic aW90LxxxxxaW90LmRhdGE3MDc=
Cache-Control: no-cache
Content-Length: 30
{"u_payload": "ping from iot"}
I was not able to correctly modify http code example to send POST request - ESP32 log says socket send success, but there is errno=128 and no information comes to the external server. Any ideas on how to deal with that?
I (7605) IoT data: ... socket send success
I (10805) IoT data: ... done reading from socket. Last read return=0 errno=128
ESP_krzychb
Contact:
Re: HTTP requests (GET, POST etc.) on ESP32
Postby ESP_krzychb » Mon Jan 02, 2017 7:41 am
Hi andrew_p,
Do you mean http as in the subject or https requests as per example you used?
If http, then I have used 03_http_request example and adopted it to perform GET requests to: Respective esp-idf components are as follows: In both cases I do not have any problems processing responses from serer.
To deal with issue you report, I would first check your application working with some common servers like above.
Krzysztof
JanJansen47
Re: HTTP requests (GET, POST etc.) on ESP32 =>> long delay
Postby JanJansen47 » Mon Jan 02, 2017 12:17 pm
I'm also new (one day) on the ESP32 platform. The examples I tried run, except the 03_http_request.
If I compare the response as seen by the ESP32 with the response as seen by the Firefox webtools, ESP32 adds a 0 at the end and tells me there is errno 128. On top of this there is a long delay (seconds) before the process starts repeating.
I tried to debug but cannot find a hint for the long delay. I don't doubt my webpage I'm using this one for a couple a years (Synology NAS).
I will try the suggestions and see if this helps. (PS I started using Google.com with the same issues)
Jan Jansen
Amsterdam
The Netherlands
ESP_krzychb
Contact:
Postby ESP_krzychb » Mon Jan 02, 2017 2:44 pm
Hi JanJansen47,
I have also seen server waiting couple of dozen seconds before closing connection.
The GET request of example code 03_http_request:
static const char *REQUEST = "GET " WEB_URL " HTTP/1.1\n"
    "Host: "WEB_SERVER"\n"
    "User-Agent: esp-idf/1.0 esp32\n"
    "\n";
does not contain Connection: close, so your server may be keeping connection open until timeout.
For my purposes I have modified the code as follows:
    "Connection: close\n"
    "\n";
This way the server (at least these I have listed in my previous post) close connection immediately after sending reply.
andrew_p
Postby andrew_p » Mon Jan 02, 2017 3:13 pm
krzychb wrote:Hi andrew_p,
I was referring to the 'official' esp-idf examples 04_https_request and 03_http_request. They both do GET request and I don't have any problems with GET, I'm trying to do POST and cannot get it work.
When I do POST with 04_https_request and specify
Content-Length: 30
It does come through and create a record with json payload on a remote server, but then ESP32 freezes after parsing a server response. I mean I see the response from the server in a terminal, but then it freezes. In other case - If I do not specify Content-Length then the request will be sent without payload, but data record will be created on a remote server anyway and ESP32 continues to run the program (after parsing the server response) without any problem.
UPDATE:
Connection: close header DOES the trick!!! 04_https_request example now works fine with POST request and ESP32 parses the server response without any problems.
andrew_p
Postby andrew_p » Mon Jan 02, 2017 5:36 pm
OK, we have a success with a POST request in 04_https_request example. But I don't need SSL handshake with the remote server, since I'm using basic authentication, so I don't need that part and want to send POST as simple as possible. So I'm playing with 03_http_request and it doesn't work.. honestly, I don't even know if it's possible to send POST via websockets or not.
Here is my log
I (199640) IoT data: Starting again!
I (199640) IoT data: Connected to AP
I (199650) IoT data: DNS lookup succeeded. IP=103.23.XX.XXX
I (199650) IoT data: ... allocated socket
I (199910) IoT data: ... connected
I (199910) IoT data: sending request=[POST https://XXXX.XXXX.com/XX/XXX/XXXXXXXX HTTP/1.1
Host: XXXXXX.XXXXXX.com
Authorization: Basic XXXXXXXXXXXXXXXXXXdGE3MDc=
Connection: close
Content-Length: 30
{"u_payload": "ping from iot"}]
I (199940) IoT data: ... socket send success
HTTP/1.0 302 Found
Location: https://XXXXXX.XXXXXX.comhttps://XXXX.XXXX.com/XX/XXX/XXXXXXXX
Server: BigIP
Connection: close
Content-Length: 0
I (200210) IoT data: ... done reading from socket. Last read return=0 errno=128
Again, just trying to find the simplest way to send POST request..
kolban
Postby kolban » Mon Jan 02, 2017 5:52 pm
An HTTP POST request occurs when your ESP32 forms a TCP/IP connection to a remote server and sends a well formed HTTP protocol header request. If all goes well, the partner will return an HTTP protocol response message. At a high level, your algorithm will be:
1. Create a socket connection to the partner.
2. Send an HTTP request message.
3. Receive an HTTP response message.
4. Close the socket.
Beyond this we have notions such as TLS/SSL for encryption of the transmitted data, various settings of HTTP headers, encodings of content, ability to keep HTTP connections open for subsequent requests ... etc etc etc.
HTTP is a protocol (not a very complex one ... but a protocol none-the-less) and has to be properly constructed for transmission and properly parsed on response. One can perform this logic in ones own code or can leverage pre-existing libraries that have been pre-written to make some of these common tasks simpler.
It may help in your posts to explain which areas of the above are the ones that are causing trouble.
andrew_p
Postby andrew_p » Mon Jan 02, 2017 6:20 pm
Neil, sorry for any confusion, I haven't worked with a low-level technologies stack since I graduated awhile ago.
Here is a detailed explanation of what I'm trying to achieve:
1. I have a remote server, which provides RESTful API over https with basic authentication (user name/password).
2. I want ESP32 to send a POST request to my remote server. I DO want to send a request over encrypted (https) connection, but there is no such thing as a certificate-based authentication on my remote server, it's just a username-password authentication.
I understand that there might be multiple ways how to achieve that (external libraries etc), I'm just trying to find the most simplest option, like 04_https_request example but maybe even simpler (if it's possible).
P.S. Neil, your book is awesome!
kolban
Postby kolban » Mon Jan 02, 2017 7:11 pm
Thanks for the kind words.
The mbedtls library exists "outside" of the ESP-IDF. I found the following article quite helpful:
https://tls.mbed.org/kb/how-to/mbedtls-tutorial
Checking my notes, I seem to have a sample found on p135 of the latest release (2017-01-01) that might form the basis for a discussion.
JanJansen47
Postby JanJansen47 » Mon Jan 02, 2017 8:48 pm
Thanks for your swift response. Indeed when the client closes the connection it's not waiting for the server. And the response is as expected. Never noticed the difference.
Jan Jansen
Amsterdam
The Netherlands
Users browsing this forum: Baidu [Spider] and 70 guests
