WiFi bottleneck as APSTA when STA can not connected
rsimpsonbusa
Postby rsimpsonbusa » Tue Dec 11, 2018 6:18 pm
Hi everybody.
Scenario:
I have an ESP32 that will be a "server" that connects to the Internet as an STA and also as a AP, hence it is setup as APSTA. Several clients ESP32s connect to the "server" and send UDP packets.
Problem:
When the Server is able to connect to the external AP there is NO problem. STA is connected to the assigned AP and the ESP32 AP section assigns IPs and receives UDP packets from the clients.
But if the Server(as an STA) can not connect to the external AP, the local AP section takes a very long time to assign an IP to its clients and receives UDP packets after a very long time (if at all), missing many UDP packets sent and. One can see that the client is waiting for the IP with the ESP_LOG at Info level.
Reasoning:
It seems that the STA keeps trying to connect to its configured SSID and causes a SERIOUS bottleneck that eats the wifi's response time and/or cpu (really don't know this). Probably its "scanning" and this is hurting the overall process.
Proof of Reasoning:
(a) When STA connects to the external AP from the start everything flows as expected.
(b) When the STA connects to the external AP some time after start work begins flowing normally. Meanwhile there is serious bottleneck which could imply that the STA is trying to connect to the external AP and eating cycles and hurting everything wifi related.
(c) If I do not configure the STA section,
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_STA, &configap));
everything works perfectly as a local AP, giving IPs in the usual fast manner.
(c1) This would mean the ESP is NOT trying to connect to the external AP and hence does not eat cpu cycles or wifi process.
(d) This was proved by commenting out the STA config section
The WiFi init section is this
void initWiFi()
	wifi_init_config_t 	cfg=WIFI_INIT_CONFIG_DEFAULT();
	wifi_config_t 		configap;
	u8 				mac[6];
	char 				textl[20];
	tcpip_adapter_init();
	ESP_ERROR_CHECK( esp_event_loop_init(wifi_event_handler, NULL));
	ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
	esp_wifi_set_ps(WIFI_PS_NONE); //otherwise multicast does not work well or at all
	ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
	esp_wifi_get_mac(ESP_IF_WIFI_STA, (uint8_t*)&mac);
	memset(&configap,0,sizeof(configap));
	if(sysConfig.ssid[1][0])!=0) //SSID for external AP and internet access
		strcpy((char *)configap.sta.ssid , sysConfig.ssid[1]);
		strcpy((char *)configap.sta.password, sysConfig.pass[1]);
	if(sysConfig.ssid[0][0])!=0) //ssid for local AP
		strcpy((char *)configap.ap.ssid,sysConfig.ssid[0]);
		strcpy((char *)configap.ap.password,sysConfig.pass[0]);
		printf("AP Loading [%s][%s]\n",configap.ap.ssid,configap.ap.password);
	else
	{ //no name given yet, assign one
		sprintf(textl,"LightIoT%02x%02x",mac[4],mac[5]);
		strcpy((char*)configap.ap.ssid,textl);
		strcpy((char*)configap.ap.password,textl);
	configap.ap.ssid_len=strlen((char *)configap.ap.ssid);
	configap.ap.authmode=WIFI_AUTH_WPA_PSK;
	configap.ap.ssid_hidden=false;
	ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &configap));
	ESP_ERROR_CHECK(esp_wifi_start());
Request:
Is this a bug? Is there a way around this problem?
Any help welcomed.
Comments:
I believe this a rather standard situation and unless I've made programming errors, it should not happen AT ALL. During normal operations an internet access can and will go down and what is going to happed is unpredictable. This makes the ESP an unreliable alternative for time critical solutions.
What's been tested:
Changed many of the config options for the Ap and the STA with no change
beacon interval,
scan option,
listen interval,
Regards.
WiFive
Re: WiFi bottleneck as APSTA when STA can not connected
Postby WiFive » Tue Dec 11, 2018 11:03 pm
Do not immediately try to reconnect in your event handler, use some kind of delay/backoff
rsimpsonbusa
Postby rsimpsonbusa » Wed Dec 12, 2018 1:20 am
Hi WiFive.
Did try that, no such luck. It really eats up the WiFi logic. The CPU seems ok, its not a busy loop or similar.
What I ended up doing is creating a sort of independent process for the STA and the AP.
Do the AP part as usual, ei,
and the launch a Task that will do a scan
	int err=esp_wifi_scan_start(&scan_config, true);
looking for the external AP and if it now found retry indefinitely. When found
ESP_ERROR_CHECK(esp_wifi_connect());
and kill the task. It actually worked :lol:
Rather primitive for a sophisticated chip wouldn't you say?
rsimpsonbusa
Postby rsimpsonbusa » Sat May 09, 2020 5:32 pm
So after some time i found the way to do it.
MUST clear the wifi_config before setting EACH of the adapter, STA and AP. So, do the usual wifi_sta config, then memset or bzero the wifi_config AGAIN and set the other adapter.
Pallanez
Postby Pallanez » Mon Jun 15, 2020 3:42 pm
Could you elaborate on this please? I'm having a similar problem.
Thanks!
Users browsing this forum: No registered users and 72 guests
