ESP32 Secure Boot - Your code only runs on your own hardware?
Posted: Sat Sep 01, 2018 3:59 pm
Hi all,
New to ESP32. I am reading the Secure Boot section on the ESP-IDF docs: https://docs.espressif.com/projects/esp ... -boot.html
The guide begins with the statement "Secure Boot is a feature for ensuring only your code can run on the chip. Data loaded from flash is verified on each reset." Understood. Is it possible to use ESP32's h/w encryption features to also ensure that our firmware only runs on our own h/w? Meaning, if someone counterfeits the hardware, but if they don't have the correct keys programmed into the ESP32 OTP, the firmware would refuse to run on counterfeit hardware.
We have not started building the hardware so we want to explore this area without say using Microchip ATSHA204 or something external.
