JTAG Debug with WROVER-KIT Example not working
Posted: Sun Apr 29, 2018 7:05 pm
Looking for some help with JTAG debugging.
I can't get the command line example working here:
http://esp-idf.readthedocs.io/en/latest ... mmand-line
I can start the Openocd fine, it looks like this:
Open On-Chip Debugger 0.10.0-dev-ga859564 (2017-07-24-16:16)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 10000 kHz
force hard breakpoints
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 10000 kHz
Info : esp32: Debug controller was reset (pwrstat=0x5F, after clear 0x0F).
Info : esp32: Core was reset (pwrstat=0x5F, after clear 0x0F).
I created gdbinit file, and started the debugger in blink directory, after setting up and make app and flash.
In the make menuconfig I have changed the flash device to USB1 (with USB0 being used by JTAG).
I get this when running gdb, which is not quite the same as the example in the web page:
GNU gdb (crosstool-NG crosstool-ng-1.22.0-75-gbaf03c2) 7.10
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-build_pc-linux-gnu --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/blink.elf...done.
0x400076dd in ?? ()
JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000
esp32: target state: halted
esp32: Core was reset (pwrstat=0x1F, after clear 0x0F).
Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400
Hardware assisted breakpoint 1 at 0x400d1f8f: file /mnt/ds216/embedded_design/esp32-projects/blink/main/blink.c, line 43.
0x0: 0x00000000
Note the line in bold above, which is different from the webpage example:
JTAG tap: esp32.slave tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
The 2nd line in bold above is where the gdb simply stops. This is different than the example:
0x0: 0x00000000
Target halted. PRO_CPU: PC=0x400DB717 (active) APP_CPU: PC=0x400D10D8
[New Thread 1073428656]
[New Thread 1073413708]
[New Thread 1073431316]
[New Thread 1073410672]
[New Thread 1073408876]
[New Thread 1073432196]
[New Thread 1073411552]
[Switching to Thread 1073411996]
Temporary breakpoint 1, app_main () at /home/user-name/esp/blink/main/./blink.c:43
43 xTaskCreate(&blink_task, "blink_task", 512, NULL, 5, NULL);
(gdb)
So it appears the debugger is freezing. I do not know what to do next. Suggestions???
I am running Ubuntu Linux 16.01. I am keeping the ESP-IDF up to date. I have had no problems building and flashing running applications.
Regards,
Greg
none separate
0x400076dd in ?? ()
0x0: 0x00000000
0x0: 0x00000000
(gdb)
Regards,
Greg
