Problem with ESP32-S3-DevKitC-1
Posted: Fri Dec 06, 2024 8:08 am
I am new to the ESP32 world and recently purchased an ESP32-S3-DevKitC-1. However, I am facing several problems with my project. Here is the list of issues:
Wi-Fi Connection Problem:
I am having trouble connecting to Wi-Fi. I always need to press my finger on the top part of the ESP32-S3 for it to connect. If I don’t, it stays stuck in a loading mode. Moreover, even when it connects to Wi-Fi (by pressing my finger), the connection drops as soon as I remove my finger.
5V Pin Issue:
I am unable to use the 5V pin. I need to supply 5V to some sensors, but I can’t get any output from the 5V pin. I tested it with an LED, but the LED doesn’t light up.
Wi-Fi Handling Issue:
I often encounter problems with Wi-Fi handling. With the code I’m using (I’ve commented out most parts for testing), it runs fine as long as I don’t touch the top part of the ESP32-S3 with my finger. However, if I touch it, it connects to Wi-Fi but immediately reboots the program (the first serial print statement, “Ask your question: …,” gets printed right before the reboot).
I know I’m new and might be making mistakes. Please feel free to point out anything I’m doing wrong. I am open to learning and improving. Thank you for your help!
5V Pin Issue:
#include <Arduino.h>
#include <WiFi.h>
#include <HTTPClient.h>
#include <ArduinoJson.h>
#include <Audio.h>
#define I2S_DOUT 37
#define I2S_BCLK 36
#define I2S_LRC 35
const char* ssid = "ssid";
const char* password = "password";
const char* chatgpt_token = "my token";
String res = "";
Audio audio;
void setup() {
Serial.begin(115200);
WiFi.mode(WIFI_STA);
WiFi.disconnect();
while (!Serial);
// wait for WiFi connection
WiFi.begin(ssid, password);
Serial.print("Connecting to ");
Serial.println(ssid);
delay(1000);
Serial.print(".");
Serial.println("connected");
Serial.print("IP address: ");
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(21); // 0...21
Serial.println("Enter text to convert to speech:");
void loop() {
Serial.print("Ask your Question : ");
while (!Serial.available()) {
audio.loop();
while (Serial.available()) {
char add = Serial.read();
res = res + add;
delay(1);
int len = res.length();
res = res.substring(0, (len - 1));
Serial.println(res);
res += " answer in 15 words";
// HTTPClient https;
// if (https.begin("https://api.openai.com/v1/chat/completions")) { // HTTPS
// https.addHeader("Content-Type", "application/json");
// String token_key = String("Bearer ") + chatgpt_token;
// https.addHeader("Authorization", token_key);
// // Create JSON payload using ArduinoJson
// DynamicJsonDocument doc(1024);
// doc["model"] = "gpt-4o-2024-11-20";
// JsonArray messages = doc.createNestedArray("messages");
// JsonObject message = messages.createNestedObject();
// message["role"] = "user";
// message["content"] = res;
// doc["max_completion_tokens"] = 30;
// String payload;
// serializeJson(doc, payload);
// int httpCode = https.POST(payload);
// Serial.println(httpCode);
// Serial.println(payload);
// if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
// String response = https.getString();
// Serial.print(response);
// DynamicJsonDocument responseDoc(2048); // Increased size to accommodate larger JSON
// deserializeJson(responseDoc, response);
// JsonObject choices_0 = responseDoc["choices"][0];
// JsonObject message = choices_0["message"];
// String Answer = message["content"].as<String>();
// Serial.print("Answer : "); Serial.println(Answer);
// audio.connecttospeech(Answer.c_str(), "en");
// } else {
// Serial.printf("[HTTPS] GET... failed, error: %s\n", https.errorToString(httpCode).c_str());
// https.end();
// } else {
// Serial.printf("[HTTPS] Unable to connect\n");
// Serial.println("Wait 10s before next round...");
// res = "";
//delay(10000);
void audio_info(const char *info) {
Serial.print("audio_info: "); Serial.println(info);
