E (80514) wifi:NAN WiFi stop
PsySc0rpi0n
Postby PsySc0rpi0n » Thu Dec 05, 2024 10:51 am
Hello.
I'm working with a device that uses a ESP32-WROVER-E, which is a LilyGo T-SIM7600G-H.
I have been trying to write a very simple code that connects the ESP32 to a WiFi network, perform an action and after the action is performed, I disconnect the ESP32 from the network and shutdown the ESP32 wireless feature so that I can save battery.
The code I have is split in 2 files: project.ino and wifi_handler.cpp.
The part of the code from project.ino that manages the WiFi connection is this:
    // WiFi connection check and retry logic
    if (millis() - last_wifi_attempt >= WIFI_RETRY_INTERVAL) {
        if (!wifi_connected) {
            // No WiFi connection, try to connect
            SerialMon.println("Attempting to connect to WiFi...");
            int wifi_status = connect_wifi(wifi_ssid, wifi_passwd);
            if (wifi_status == 1) {
                GOT_HERE();
                wifi_connected = true;
                SerialMon.println("Connected to WiFi!");
            } else if (wifi_status == 0) {
                SerialMon.println("Failed to connect to WiFi.");
                GOT_HERE();
            } else if (wifi_status == -1) {
                SerialMon.println("Connection in progress...");
                GOT_HERE();
        // If WiFi is connected, proceed with data submission
        if (wifi_connected) {
            String address = get_address_from_coordinates(loc.lat, loc.lon);
            snprintf(description, BUFFER, address.c_str());
            send_to_database(sensorID,
                             loc.lat, loc.lon,
                             distance,
                             weight,
                             description);
	    int disconnect_status = disconnect_wifi();
	    if (disconnect_status == 0){
		SerialMon.println("WiFi Disconnected.");
	    } else if (disconnect_status == 1){
		SerialMon.println("WiFi not connected.");
		SerialMon.println("Failed to disconnect from WiFi");
            last_wifi_attempt = millis();  // Update last_wifi_attempt to prevent immediate retry
The code I have for connect_wifi() and disconnect_wifi() is the following:
connect_wifi()
int connect_wifi(const char* ssid, const char* pwd){
    wl_status_t wifi_status = WiFi.status();
    if (WiFi.status() == WL_CONNECTED){
        return 1; // Already connected
    if (wifi_status == WL_DISCONNECTED   ||
        wifi_status == WL_NO_SHIELD      ||
        wifi_status == WL_IDLE_STATUS    ||
        wifi_status == WL_CONNECT_FAILED){
        WiFi.mode(WIFI_STA);
        WiFi.begin(ssid, pwd);
        unsigned long connect_start = millis();
        while(WiFi.status() != WL_CONNECTED &&
              (millis() - connect_start < 5000)){
            delay(500);
            SerialMon.print(".");
            return 1; // Connection successfull
            return 0; // Connection to WiFi failed
        return 1; // Connection in progress
    return -1;
and disconnect_wifi():
int disconnect_wifi(){
     * 0 -> WiFi disconnected successfully
     * 1 - WiFi is not connected
     * 2 - Failed to disconenct (timeout)
    if (WiFi.status() != WL_CONNECTED){
        return 1; // No action needed. We are not connected,
                  // so no disconnect needed
    WiFi.disconnect(true);
    unsigned long start_time = millis();
    while(WiFi.status() == WL_CONNECTED && millis() - start_time < 1000){
        delay(100);
        WiFi.mode(WIFI_OFF);
        delay(100);
        return 0; // WiFi disconencted and hardware is OFF to save battery
        return 2; // WiFi, for some reason, didn't disconnect
What happens is that when the diconnect_function() is called, I always get the E (80514) wifi:NAN WiFi stop, which leads later to more issues like, for some reason, the connect_wifi() functions seems not to be called again as if the WiFi is still connected.
Is there anythin obvious in the code that might be triggering this behaviour?
Users browsing this forum: No registered users and 128 guests
