Using IDF in vscode but want to add support for a 4G USB modem eg from esp-iot-solution repository
Posted: Sun Dec 01, 2024 5:53 am
Hi
I am developing a project using ESP32-S3 IDF SDK 5.3.1 in vscode
I am now wanting to add support for a 4G modem module using the USB port.
I thought I would start with the example project usb_cdc_4g_module. I downloaded this directory and opened it in vscode. I found the
iot_usbh_modem component does not exist in IDF.
My ultimate goal is to merge this functionality into my main project using my local IDF installation. But is esp-iot-solution compatible with IDF?
I downloaded and copied all usb sub directories including iot_usbh_modem into my ...\esp\v5.3.1\esp-idf\components\usb directory
I edited my idf_component.yml file so it could find the iot_usbh_modem directory
I configured the project with menuconfig and successfully built and flashed the project.
But when I run it I get the following logs:
I found and downloaded binary files on the waveshare site:
https://www.waveshare.com/wiki/ESP32-S3 ... _WIFI_Demo
and loaded them.
With this file there is no crash and the process gets a lot further and trying to send AT commands as follows, so I think my hardware setup is ok:
I would appreciate some help on how to resolve this, or a steer on what my approach should be. Another option I am considering is cloning the entire https://github.com/espressif/esp-iot-solution repository into my esp directory alongside my IDF "v5.3.1" directory and trying to select this and build. Does this make sense? I am also not sure if other components and include files etc may be missing from the esp-iot-solution repository breaking my existing project.
I don't understand how to manage different Espressif ESP32 repositories.
version: "^1.0.0"
override_path: "/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_modem"
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x1918
load:0x403c8700,len:0x4
load:0x403c8704,len:0xe5c
load:0x403cb700,len:0x303c
entry 0x403c893c
I (23) boot: ESP-IDF v5.3.1-dirty 2nd stage bootloader
I (24) boot: compile time Dec 1 2024 18:12:53
I (24) boot: Multicore bootloader
I (27) boot: chip revision: v0.2
I (31) qio_mode: Enabling default flash chip QIO
I (36) boot.esp32s3: Boot SPI Speed : 80MHz
I (41) boot.esp32s3: SPI Mode : QIO
I (46) boot.esp32s3: SPI Flash Size : 16MB
I (51) boot: Enabling RNG early entropy source...
I (56) boot: Partition Table:
I (60) boot: ## Label Usage Type ST Offset Length
I (67) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (319) app_init: App version: 1
I (323) app_init: Compile time: Dec 1 2024 18:12:55
I (329) app_init: ELF file SHA256: 0461e8c61...
I (334) app_init: ESP-IDF: v5.3.1-dirty
I (340) efuse_init: Min chip rev: v0.0
I (354) heap_init: Initializing. RAM available for dynamic allocation:
I (361) heap_init: At 3FCA6128 len 000435E8 (269 KiB): RAM
I (368) heap_init: At 3FCE9710 len 00005724 (21 KiB): RAM
I (374) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (380) heap_init: At 600FE100 len 00001EE8 (7 KiB): RTCRAM
I (387) spi_flash: detected chip: gd
I (390) spi_flash: flash io: qio
I (395) sleep: Configure to isolate all GPIO pins in sleep state
I (401) sleep: Enable automatic switching of GPIO sleep configuration
I (408) main_task: Started on CPU0
I (436) main_task: Calling app_main()
I (436) gpio: GPIO[18]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (439) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (448) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (457) gpio: GPIO[17]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (477) led_indicator: LED Indicator Version: 0.3.0
I (477) gpio: GPIO[15]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (482) led_indicator: blink_lists is null, use default blink list
W (489) led_indicator: ./managed_components/espressif__led_indicator/src/led_indicator.c:280 (_led_indicator_create_com):LED indicator does not have the hal_indicator_set_brightness function
I (506) led_indicator: Indicator create successfully. type:GPIO mode, hardware_data:0xf, is_active_level_high:1, blink_lists:default
I (519) led_indicator: LED Indicator Version: 0.3.0
I (524) gpio: GPIO[17]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (533) led_indicator: blink_lists is null, use default blink list
W (540) led_indicator: ./managed_components/espressif__led_indicator/src/led_indicator.c:280 (_led_indicator_create_com):LED indicator does not have the hal_indicator_set_brightness function
I (558) led_indicator: Indicator create successfully. type:GPIO mode, hardware_data:0x11, is_active_level_high:1, blink_lists:default
I (571) led_indicator: LED Indicator Version: 0.3.0
I (576) gpio: GPIO[16]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (585) led_indicator: blink_lists is null, use default blink list
W (592) led_indicator: ./managed_components/espressif__led_indicator/src/led_indicator.c:280 (_led_indicator_create_com):LED indicator does not have the hal_indicator_set_brightness function
I (610) led_indicator: Indicator create successfully. type:GPIO mode, hardware_data:0x10, is_active_level_high:1, blink_lists:default
I (628) 4g_main: ====================================
I (628) 4g_main: ESP 4G Cat.1 Wi-Fi Router
I (633) 4g_main: ====================================
I (639) modem_board: iot_usbh_modem, version: 1.0.0
I (645) modem_board: Force reset modem board....
I (650) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (659) modem_board: Resetting modem using io=13, level=0
I (865) modem_board: Waiting for modem initialize ready
I (5865) USBH_CDC: iot usbh cdc version: 1.0.0
I (5895) esp-modem: --------- Modem PreDefined Info ------------------
I (5896) esp-modem: Model: User Defined
I (5896) esp-modem: Modem itf 0
I (5900) esp-modem: ----------------------------------------------------
I (5908) gpio: GPIO[12]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (5917) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x42018c9b PS : 0x00060930 A0 : 0x82018dee A1 : 0x3fcb3600
--- 0x42018c9b: _cdc_transfers_allocate at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:497
A2 : 0x00000000 A3 : 0x3fcb3a20 A4 : 0xffffffff A5 : 0x3fcb4884
A6 : 0x3fcb3648 A7 : 0x3fcb4860 A8 : 0x3fcbdfc4 A9 : 0x42018a80
--- 0x42018a80: out_xfer_cb at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:420
A10 : 0x00000000 A11 : 0x00000000 A12 : 0x3fcb4870 A13 : 0x00000000
A14 : 0x00000000 A15 : 0x3fcb3604 SAR : 0x00000016 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000001 LBEG : 0x400570e8 LEND : 0x400570f3 LCOUNT : 0xffffffff
--- 0x400570e8: memset in ROM
0x400570f3: memset in ROM
Backtrace: 0x42018c98:0x3fcb3600 0x42018deb:0x3fcb3630 0x420190b1:0x3fcb3680 0x4201b1f1:0x3fcb36b0 0x42019192:0x3fcb36e0 0x4037e545:0x3fcb3700
--- 0x42018c98: _cdc_transfers_allocate at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:496
0x42018deb: _cdc_open at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:625
0x420190b1: usb_event_cb at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:243
0x4201b1f1: usb_host_client_handle_events at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/usb_host.c:809
0x42019192: usbh_cdc_client_task at C:/Users/micha/esp/v5.3.1/esp-idf/components/usb/iot_usbh_cdc/iot_usbh_cdc.c:198
0x4037e545: vPortTaskWrapper at C:/Users/micha/esp/v5.3.1/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:134
and loaded them.
Build:Mar 27 2021
SPIWP:0xee
load:0x3fce3818,len:0x1870
load:0x403c9700,len:0x4
load:0x403c9704,len:0xda4
load:0x403cc700,len:0x3130
entry 0x403c9934
I (24) boot: ESP-IDF v5.1-dirty 2nd stage bootloader
I (24) boot: compile time Nov 15 2023 09:59:09
I (46) boot.esp32s3: SPI Flash Size : 4MB
I (74) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (82) boot: 2 factory factory app 00 00 00010000 00100000
I (89) boot: 3 storage Unknown data 01 82 00110000 00100000
I (97) boot: End of partition table
I (101) esp_image: segment 0: paddr=00010020 vaddr=3c0a0020 size=2c7c8h (182216) map
I (137) esp_image: segment 1: paddr=0003c7f0 vaddr=3fc9b600 size=03828h ( 14376) load
I (140) esp_image: segment 2: paddr=00040020 vaddr=42000020 size=9f73ch (653116) map
I (242) esp_image: segment 3: paddr=000df764 vaddr=3fc9ee28 size=00d44h ( 3396) load
I (243) esp_image: segment 4: paddr=000e04b0 vaddr=40374000 size=17510h ( 95504) load
I (276) boot: Loaded app from partition at offset 0x10000
I (276) boot: Disabling RNG early entropy source...
I (287) cpu_start: Multicore app
I (287) cpu_start: Pro cpu up.
I (288) cpu_start: Starting app cpu, entry point is 0x403758dc
I (0) cpu_start: App cpu up.
I (305) cpu_start: Pro cpu start user code
I (305) cpu_start: cpu freq: 240000000 Hz
I (306) cpu_start: Application information:
I (309) cpu_start: Project name: usb_cdc_4g_module
I (314) cpu_start: App version: aab3785e-dirty
I (320) cpu_start: Compile time: Nov 15 2023 15:18:40
I (326) cpu_start: ELF file SHA256: 872601badd04bbe3...
I (332) cpu_start: ESP-IDF: v5.1-dirty
I (337) cpu_start: Min chip rev: v0.0
I (342) cpu_start: Max chip rev: v0.99
I (347) cpu_start: Chip rev: v0.2
I (351) heap_init: Initializing. RAM available for dynamic allocation:
I (359) heap_init: At 3FCA3218 len 000464F8 (281 KiB): DRAM
I (365) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (372) heap_init: At 3FCF0000 len 00008000 (32 KiB): DRAM
I (378) heap_init: At 600FE010 len 00001FF0 (7 KiB): RTCRAM
I (384) spi_flash: detected chip: gd
I (388) spi_flash: flash io: qio
W (392) spi_flash: Detected size(16384k) larger than the size in the binary image header(4096k). Using the size in the binary image header.
I (405) sleep: Configure to isolate all GPIO pins in sleep state
I (412) sleep: Enable automatic switching of GPIO sleep configuration
I (419) app_start: Starting scheduler on CPU0
I (424) app_start: Starting scheduler on CPU1
I (424) main_task: Started on CPU0
I (434) main_task: Calling app_main()
I (445) 4g_main: ====================================
I (445) 4g_main: ESP 4G Cat.1 Wi-Fi Router
I (448) 4g_main: ====================================
I (454) modem_board: iot_usbh_modem, version: 0.2.0
I (460) modem_board: Force reset modem board....
I (465) gpio: GPIO[33]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (474) modem_board: Resetting modem using io=33, level=1
I (680) modem_board: Waiting for modem initialize ready
I (5730) USB_HCDC: iot_usbh_cdc, version: 0.2.0
I (5730) IOT_USBH: iot_usbh, version: 0.2.0
I (5760) IOT_USBH: USB Port=1 init succeed, fifo strategy=0
I (5760) IOT_USBH: usb port start succeed
I (5760) IOT_USBH: USB Processing Start
I (5760) USB_HCDC: usbh cdc driver install succeed
I (5764) IOT_USBH: Waiting USB Connection
I (5770) USB_HCDC: Waiting CDC Device Connection
I (5774) IOT_USBH: Port power: ON Succeed
I (5760) USB_HCDC: CDC task start
I (7925) IOT_USBH: line 131 PORT_EVENT_CONNECTION
I (8025) IOT_USBH: Resetting Port
I (8085) IOT_USBH: Port reset succeed
I (8085) IOT_USBH: Getting Port Speed
I (8085) IOT_USBH: USB Speed: full-speed
I (8087) IOT_USBH: Pipe init succeed, addr: 00
I (8092) IOT_USBH: Set Device Addr = 1
I (8097) IOT_USBH: Set Device Addr Done
I (8101) IOT_USBH: get device desc
I (8105) IOT_USBH: get device desc, actual_num_bytes:26
*** Device descriptor ***
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0xef
bDeviceSubClass 0x2
bDeviceProtocol 0x1
bMaxPacketSize0 64
idVendor 0x1e0e
idProduct 0x9011
bcdDevice 1.00
iManufacturer 1
iProduct 2
iSerialNumber 3
bNumConfigurations 1
I (8135) IOT_USBH: get short config desc
I (8140) IOT_USBH: get config desc, actual_num_bytes:16
I (8145) IOT_USBH: get full config desc
I (8150) IOT_USBH: get full config desc, actual_num_bytes:253
*** Configuration descriptor ***
bLength 9
bDescriptorType 2
wTotalLength 245
bNumInterfaces 6
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
bMaxPower 500mA
*** Interface Association Descriptor ***
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 0xe0
bFunctionSubClass 0x1
bFunctionProtocol 0x3
iFunction 5
*** Interface descriptor ***
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 0xe0
bInterfaceSubClass 0x1
bInterfaceProtocol 0x3
iInterface 5
*** Endpoint descriptor ***
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 0x3 INT
wMaxPacketSize 64
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 0xa
bInterfaceSubClass 0x0
bInterfaceProtocol 0x0
iInterface 5
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 0x2 BULK
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xc EP 12 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 0xff
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xb EP 11 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 3
iInterface 11
bLength 7
bDescriptorType 5
bEndpointAddress 0x89 EP 9 IN
wMaxPacketSize 64
bInterval 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xf EP 15 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 3
iInterface 11
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
wMaxPacketSize 64
bInterval 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xa EP 10 OUT
wMaxPacketSize 64
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
iInterface 8
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
wMaxPacketSize 16
bInterval 16
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
wMaxPacketSize 64
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0xe EP 14 OUT
wMaxPacketSize 64
bInterval 0
I (8492) IOT_USBH: Set Device Configuration = 1
I (8498) IOT_USBH: Set Device Configuration Done
I (8503) IOT_USBH: Pipe init succeed, addr: 86
I (8508) IOT_USBH: Pipe init succeed, addr: 0F
I (8513) USB_HCDC: CDC Device Connected
I (8518) esp-modem: --------- Modem PreDefined Info ------------------
I (8525) esp-modem: Model: User Defined
I (8529) esp-modem: Modem itf: IN Addr:0x86, OUT Addr:0x0F
I (8536) esp-modem: ----------------------------------------------------
I (8543) gpio: GPIO[33]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (8553) USB_HCDC: rx0 flush -0 = 0
I (8553) modem_board: DTE reconnect, reconnecting ...
I (9562) modem_board: reconnect after 5s...
I (10562) modem_board: reconnect after 4s...
I (11562) modem_board: reconnect after 3s...
I (12562) modem_board: reconnect after 2s...
I (13562) modem_board: reconnect after 1s...
I (13562) modem_board: Modem state STAGE_SYNC, Start
E (13578) esp-modem-dte: esp_dte_handle_line(79): handle line failed
E (13585) esp-modem-dte: esp_dte_handle_line(79): handle line failed
I (13585) modem_board: Network Auto reconnecting ...
W (13587) 4g_main: Modem Board Event: Network disconnected
I (13587) modem_board: Modem state STAGE_SYNC, Success!
I (13699) modem_board: Modem state STAGE_CHECK_SIM, Start
W (13706) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (15706) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (15706) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (15718) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (15720) modem_board: Get SIM card state failed
W (15726) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry1, after 3000ms...
I (18734) modem_board: Modem state STAGE_CHECK_SIM, Start
W (18741) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (20741) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (20741) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (20754) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (20755) modem_board: Get SIM card state failed
W (20761) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry2, after 3000ms...
I (23769) modem_board: Modem state STAGE_CHECK_SIM, Start
W (23776) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (25776) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (25776) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (25789) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (25790) modem_board: Get SIM card state failed
W (25796) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry3, after 3000ms...
I (28804) modem_board: Modem state STAGE_CHECK_SIM, Start
W (28811) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (30811) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (30811) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (30824) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (30825) modem_board: Get SIM card state failed
W (30831) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry4, after 3000ms...
I (33839) modem_board: Modem state STAGE_CHECK_SIM, Start
W (33846) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (35846) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (35846) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (35859) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (35860) modem_board: Get SIM card state failed
E (35866) modem_board: Modem state STAGE_CHECK_SIM, retry 5, timeout !
W (35873) modem_board: Retry From Start !
I (35877) modem_board: Modem state STAGE_SYNC, Start
I (35906) modem_board: Network Auto reconnecting ...
W (35906) 4g_main: Modem Board Event: Network disconnected
I (35906) modem_board: Modem state STAGE_SYNC, Success!
I (36012) modem_board: Modem state STAGE_CHECK_SIM, Start
W (36019) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (38019) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (38019) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (38032) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (38033) modem_board: Get SIM card state failed
W (38039) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry1, after 3000ms...
I (41047) modem_board: Modem state STAGE_CHECK_SIM, Start
W (41054) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (43054) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (43054) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (43067) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (43068) modem_board: Get SIM card state failed
W (43074) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry2, after 3000ms...
I (46082) modem_board: Modem state STAGE_CHECK_SIM, Start
W (46089) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (48089) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (48089) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (48102) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (48103) modem_board: Get SIM card state failed
W (48109) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry3, after 3000ms...
I (51117) modem_board: Modem state STAGE_CHECK_SIM, Start
W (51124) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
E (53124) esp-modem-dte: esp_modem_dte_send_cmd(268): process command timeout
W (53124) esp_modem_dce: esp_modem_dce_generic_command(26): Command:AT+CPIN= response timeout
W (53137) esp_modem_dce: esp_modem_dce_generic_command(31): Command:AT+CPIN?
...failed
W (53138) modem_board: Get SIM card state failed
W (53144) modem_board: Modem state STAGE_CHECK_SIM, Failed, retry4, after 3000ms...
