Bizarre behavior with C6, Arduino and RTC_NOINIT_ATTR variable
Posted: Fri Nov 08, 2024 10:27 am
I'm programming a C6 in Arduino mode with pioarduino. My code has a boolean value that has to swap back-n-forth to properly operate an electrical motor (one time in one direction, one time in the other, etc.) Yet, from time to time, I need to soft reboot my device and when doing so, it will always reset to the default value of the variable (true) rather than the "right" value.
So I thought about tagging my value with RTC_NOINIT_ATTR:
Then, my code is pretty basic (simplified here):
(I know I could simplify this but I truly want to make sure I don't have two signals HIGH at the same time for some reason)
Now, when I do this... nothing happens! Which is very odd. As if my variable could possibly be read, but any write doesn't go back to memory or is not read back as modified. Is that even possible? What am I doing wrong? Ideas are welcomed!
- RTC_NOINIT_ATTR boolean engineBalanceDirection = true;
- void wallclock_force_forward()
- if (engineBalanceDirection)
- digitalWrite(ENGINE_BALANCE_1, HIGH); // activate A+ on L293D
- digitalWrite(ENGINE_BALANCE_2, LOW); // de-activate A- on L293D
- else
- digitalWrite(ENGINE_BALANCE_1, LOW); // de-activate A+ on L293D
- digitalWrite(ENGINE_BALANCE_2, HIGH); // activate A- on L293D
- engineBalanceDirection = !engineBalanceDirection;
- delay(IMPULSE_DURATION_MS); // wait 1/2 second
- // stop it all - de-activate A+ and A- on L293D
