I have a code which has different functions for reading and writing holding registers and coils and reading input registers. Of these 5 functions, the function for reading input registers is not working. According to the error message the CID declaration is wrong but it seems right. Can anybody please help me with what is wrong here?
The error I am getting:
E (449) MB_CONTROLLER_MASTER: mbc_serial_master_get_parameter: The requested cid(2) is not configured correctly. Check data dictionary for correctness.
E (459) MB_CONTROLLER_MASTER: mbc_master_get_parameter(74): Master get parameter failure, error=(0x102) (ESP_ERR_INVALID_ARG).
E (469) MASTER_TEST: Characteristic #2 (Length) read failed, err = 0x102 (ESP_ERR_INVALID_ARG).
The function call:
float test1 = master_read_input_register(2);
Read Input function:
float master_read_input_register(uint16_t cid) {
esp_err_t err = ESP_OK;
float value = NAN; // Default to NAN to indicate an error if read fails
const mb_parameter_descriptor_t* param_descriptor = NULL;
bool alarm_state = false;
ESP_LOGI(TAG, "Start reading input register for CID: %u...", cid);
// Get parameter descriptor for the provided CID
err = mbc_master_get_cid_info(cid, ¶m_descriptor);
if ((err != ESP_ERR_NOT_FOUND) && (param_descriptor != NULL) && param_descriptor->mb_param_type == MB_PARAM_INPUT) {
void* temp_data_ptr = master_get_param_data(param_descriptor);
assert(temp_data_ptr);
uint8_t type = 0;
err = mbc_master_get_parameter(cid, (char*)param_descriptor->param_key,
(uint8_t*)temp_data_ptr, &type);
if (err == ESP_OK) {
uint16_t raw_value = *(uint16_t*)temp_data_ptr;
ESP_LOGI(TAG, "Raw value = %u", raw_value);
value = (float)raw_value; // Convert raw value to float
ESP_LOGI(TAG, "Characteristic #%u %s (%s) value = %f read successfully.",
param_descriptor->cid,
param_descriptor->param_units,
value);
// Check if value is within the expected range
if ((value > param_descriptor->param_opts.max) || (value < param_descriptor->param_opts.min)) {
ESP_LOGW(TAG, "Value is out of range: %f", value);
alarm_state = true; // Set alarm if value is out of range
return NAN; // Return NAN if the value is out of range
ESP_LOGE(TAG, "Characteristic #%u (%s) read failed, err = 0x%x (%s).",
(int)err,
(char*)esp_err_to_name(err));
ESP_LOGE(TAG, "Parameter descriptor not found or invalid type for CID: %u", cid);
if (alarm_state) {
ESP_LOGI(TAG, "Alarm triggered by CID #%u.", param_descriptor->cid);
return value;
CID definition:
enum {
CID_HOLD_DATA_0 = 0, // Unique identifier for the 'Length' parameter (for reading)
CID_HOLD_DATA_1, // Unique identifier for the 'sending data' parameter (for writing)
CID_INPUT_DATA_0 = 2, // Unique identifier for the 'Length' parameter in input registers
CID_COIL_0, // Unique identifier for the coil
CID_COUNT
const mb_parameter_descriptor_t device_parameters[] = {
{ CID_HOLD_DATA_0, STR("Length"), STR("cm"), 1, MB_PARAM_HOLDING, 775, 2,
HOLD_OFFSET(holding_data0), PARAM_TYPE_FLOAT, 4, OPTS_NO_LIMIT, PAR_PERMS_READ_WRITE_TRIGGER },
{ CID_HOLD_DATA_1, STR("sending data"), STR("words.."), 1, MB_PARAM_HOLDING, 775, 2, // Same address
HOLD_OFFSET(holding_data1), PARAM_TYPE_FLOAT, 4, OPTS_NO_LIMIT, PAR_PERMS_READ_WRITE_TRIGGER },
{ CID_INPUT_DATA_0, STR("Length"), STR("cm"), 1, MB_PARAM_INPUT, 770, 2,
INPUT_OFFSET(input_data0), PARAM_TYPE_FLOAT, 4, OPTS_NO_LIMIT, PAR_PERMS_READ },
{ CID_COIL_0, STR("Coil_0"), STR("state"), 1, MB_PARAM_COIL, 522, 1, // Address 522, 1-bit size
0, PARAM_TYPE_U8, 1, OPTS_NO_LIMIT, PAR_PERMS_READ_WRITE_TRIGGER }
Not able to read Input registers via Modbus
Users browsing this forum: No registered users and 132 guests
