mbedtls_ssl_setup returned -0x7F00 after 11h task running.
nightsky_sk
Postby nightsky_sk » Mon Jul 22, 2024 10:58 am
The code is compliled based on serval examples in ESP -IDF 5.1.4 One of biggest portion is coming from https://github.com/FreeRTOS/iot-reference-esp32c3/ as I wanted to use mqtt-agent
However, I've noticed that after about 11 hours, the application is losing connection with AWS IoT server. So I've set up some devices to understand this behaviour better.
First what I found out that each of 6 device loose this connection after approximately 11-12 h
id       avr time between disconnect (s)
GA97DF0001    42086.690
GA97DF0002    42599.138
GA97DF0003    41970.993
GA97DF0004    39538.257
GA97DF0005    39316.676
GA97DF0006    39731.619
39000s = 10.8h
42000s = 11.6h
Device with id 1-3 are connected to different wifi router and network than devices 4-6,
Also similar frequency I've noticed based on database records in another location, so at this point I kind of excluded router settings or wifi network configuration as potential reason.
This mean that is time to capture some logs from device:
2024-07-21 22:03:02	E (38279117) coreMQTT: sendMessageVector: Unable to send packet: Network Error.
E (38279127) coreMQTT: MQTT PUBLISH failed with status MQTTSendFailed.
E (38279127) coreMQTT: MQTT operation failed with status MQTTSendFailed
I (38279177) supervisor: coreMQTT-Agent disconnected. Preventing coreMQTT-Agent commands from being enqueued.
I (38279147) gate_control: Task "GateReport" sending publish request to coreMQTT-Agent with message "{"openReceived": 0,"gateSensors":{ "IN1": 0, "IN2": 0},"keyboard":{ "new_key": 0, "key": ""}, "iteration": 4141}" on topic "/gates/GA97DF0004" with ID 12438.
I (38279187) ota_over_mqtt: coreMQTT-Agent disconnected. Suspending OTA agent.
I (38279227) core_mqtt_agent_manager: coreMQTT-Agent disconnected.
E (38279307) esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
E (38279317) esp-tls: create_ssl_handle failed
E (38279317) esp-tls: Failed to open new connection
2024-07-21 22:03:03	I (38279627) core_mqtt_agent_manager: Retry attempt 1.
2024-07-21 22:03:03	E (38279767) esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
E (38279777) esp-tls: create_ssl_handle failed
E (38279777) esp-tls: Failed to open new connection
2024-07-21 22:03:03	I (38280227) core_mqtt_agent_manager: Retry attempt 2.
2024-07-21 22:03:04	E (38280387) esp-tls-mbedtls: mbedtls_ssl_setup returned -0x7F00
E (38280387) esp-tls: create_ssl_handle failed
E (38280387) esp-tls: Failed to open new connection
2024-07-21 22:03:05	I (38281867) core_mqtt_agent_manager: Retry attempt 3.
redspike666
Re: mbedtls_ssl_setup returned -0x7F00 after 11h task running.
Postby redspike666 » Wed Oct 30, 2024 10:30 am
Did you ever find a solution to this?
Users browsing this forum: No registered users and 103 guests
