Newbie questions
Posted: Thu Dec 21, 2017 12:04 am
i just starting with ESP32 Wroom
How can i find out which System is already installed ?
Can i install Lua ?. Where can i get the image ? Or do i have tp compile mysef ?
thanks for help
PORT OPEN 115200
Communication with MCU..
PORT CLOSED
PORT OPEN 115200
Communication with MCU..Got answer! Communication with MCU established.
AutoDetect firmware...
Can't autodetect firmware, because proper answer not received (may be unknown firmware).
Please, reset module or continue.
1000[0m
[0;32mI (153) boot: 1 otadata OTA data 01 00 00010000 00002000[0m
[0;32mI (177) boot: 2 nvs WiFi data 01 02 00012000 0000e000[0m
[0;32mI (200) boot: 3 at_customize unknown 40 00 00020000 000e0000[0m
[0;32mI (223) boot: 4 ota_0 OTA app 00 10 00100000 00180000[0m
[0;32mI (246) boot: 5 ota_1 OTA app 00 11 00280000 00180000[0m
[0;32mI (270) boot: End of partition table[0m
[0;32mI (283) boot: Disabling RNG early entropy source...[0m
[0;32mI (300) boot: Loading app partition at offset 00100000[0m
[0;32mI (1475) boot: segment 0: paddr=0x00100018 vaddr=0x00000000 size=0x0ffe8 ( 65512) [0m
[0;32mI (1476) boot: segment 1: paddr=0x00110008 vaddr=0x3f400010 size=0x1c5d0 (116176) map[0m
[0;32mI (1492) boot: segment 2: paddr=0x0012c5e0 vaddr=0x3ffb0000 size=0x0215c ( 8540) load[0m
[0;32mI (1523) boot: segment 3: paddr=0x0012e744 vaddr=0x40080000 size=0x00400 ( 1024) load[0m
[0;32mI (1546) boot: segment 4: paddr=0x0012eb4c vaddr=0x40080400 size=0x1b028 (110632) load[0m
[0;32mI (1625) boot: segment 5: paddr=0x00149b7c vaddr=0x400c0000 size=0x00034 ( 52) load[0m
[0;32mI (1626) boot: segment 6: paddr=0x00149bb8 vaddr=0x00000000 size=0x06450 ( 25680) [0m
[0;32mI (1642) boot: segment 7: paddr=0x00150010 vaddr=0x400d0018 size=0x7a544 (501060) map[0m
[0;32mI (1670) heap_alloc_caps: Initializing. RAM available for dynamic allocation:[0m
[0;32mI (1692) heap_alloc_caps: At 3FFBA6B8 len 00025948 (150 KiB): DRAM[0m
[0;32mI (1713) heap_alloc_caps: At 3FFE8000 len 00018000 (96 KiB): D/IRAM[0m
[0;32mI (1735) heap_alloc_caps: At 4009B428 len 00004BD8 (18 KiB): IRAM[0m
[0;32mI (1755) cpu_start: Pro cpu up.[0m
[0;32mI (1767) cpu_start: Single core mode[0m
[0;32mI (1780) cpu_start: Pro cpu start user code[0m
[0;32mI (1840) cpu_start: Starting scheduler on PRO CPU.[0m
[0;32mI (2097) uart: queue free spaces: 10[0m
I (2099) wifi: wifi firmware version: c604573
I (2099) wifi: config NVS flash: enabled
I (2099) wifi: config nano formating: disabled
I (2106) wifi: Init dynamic tx buffer num: 32
I (2107) wifi: wifi driver task: 3ffc4da4, prio:23, stack:3584
I (2112) wifi: Init static rx buffer num: 10
I (2116) wifi: Init dynamic rx buffer num: 0
I (2120) wifi: Init rx ampdu len mblock:7
I (2124) wifi: Init lldesc rx ampdu entry mblock:4
I (2128) wifi: wifi power manager task: 0x3ffca14c prio: 21 stack: 2560
I (2135) wifi: wifi timer task: 3ffcb1cc, prio:22, stack:3584
[0;31mE (2140) phy_init: PHY data partition validated[0m
[0;32mI (2234) phy: phy_version: 329, Feb 22 2017, 15:58:07, 0, 0[0m
I (2235) wifi: mode : softAP (30:ae:a4:1e:8d:f1)
I (2238) wifi: mode : sta (30:ae:a4:1e:8d:f0) + softAP (30:ae:a4:1e:8d:f1)
I (2241) wifi: mode : softAP (30:ae:a4:1e:8d:f1)
thanks for help
PORT OPEN 115200
PORT CLOSED
PORT OPEN 115200
1000[0m
