I am using ESP32-S3-WROOM-1-N16R2 in my design. I want to use one sensor which has both I2C and SPI Communication. I want give provision for both. I gone through the datasheet of this microcontroller. I don't find which specific pins are used for I2C(SDA, SCL) and SPI (MOSI, MISO, CS, SCK) Communication. I am new to this. Can anyone guide me?
Thanks,
Kuralmozhi
Which Pins are used for I2C and SPI Communication in ESP32 - S3?
Re: Which Pins are used for I2C and SPI Communication in ESP32 - S3?
Any of them. The ESP32-S3 has a GPIO matrix that allows you to route those peripherals to any (not otherwise used) GPIO pin.
(Technically, the ESP32-S3 also has some dedicated pins that you can route SPI to via a different mechanism; if you need the absolutely 100% fastest SPI speed possible, you could use that. But for general purpose, any pin works.)
Users browsing this forum: No registered users and 79 guests
