HTTPS connection fail.
Hi, I'm trying to send a POST request to a server using my ESP32-S3. The HTTPs connection was working fine until I added some of the mqtt broker connection bits. I'm using the esp_crt_bundle to verify the server. As you can see from the logs, it shows certificate verified, but the connection is failed. Can you please advice on this issue?
- Screenshot 2024-04-24 144834.png (25.03 KiB) Viewed 626 times
Re: HTTPS connection fail.
Please refer to the more detailed logs below:
I (733475) MQTT: ########## ########### ###########
I (733515) mbedtls: ssl_tls.c:3919 => handshake
I (733515) mbedtls: ssl_msg.c:2358 => flush output
I (733515) mbedtls: ssl_msg.c:2367 <= flush output
I (733525) mbedtls: ssl_tls.c:3838 client state: MBEDTLS_SSL_HELLO_REQUEST
I (733525) mbedtls: ssl_msg.c:2358 => flush output
I (733535) mbedtls: ssl_msg.c:2367 <= flush output
I (733535) mbedtls: ssl_tls.c:3838 client state: MBEDTLS_SSL_CLIENT_HELLO
I (733545) mbedtls: ssl_client.c:924 => write client hello
I (733555) mbedtls: ssl_msg.c:2788 => write handshake message
I (733565) mbedtls: ssl_msg.c:2948 => write record
I (733565) mbedtls: ssl_msg.c:3085 <= write record
I (733575) mbedtls: ssl_msg.c:2909 <= write handshake message
I (733575) mbedtls: ssl_client.c:1012 <= write client hello
I (733585) mbedtls: ssl_msg.c:2358 => flush output
I (733585) mbedtls: ssl_msg.c:2372 message length: 141, out_left: 141
I (733595) mbedtls: ssl_msg.c:2379 ssl->f_send() returned 141 (-0xffffff73)
I (733605) mbedtls: ssl_msg.c:2406 <= flush output
I (733615) mbedtls: ssl_tls.c:3838 client state: MBEDTLS_SSL_SERVER_HELLO
I (733615) mbedtls: ssl_tls12_client.c:1193 => parse server hello
I (733625) mbedtls: ssl_msg.c:4122 => read record
I (733635) mbedtls: ssl_msg.c:2160 => fetch input
I (733635) mbedtls: ssl_msg.c:2300 in_left: 0, nb_want: 5
I (733645) mbedtls: ssl_msg.c:2320 in_left: 0, nb_want: 5
I (733645) mbedtls: ssl_msg.c:2323 ssl->f_recv(_timeout)() returned 5 (-0xfffffffb)
I (733655) mbedtls: ssl_msg.c:2345 <= fetch input
I (733665) mbedtls: ssl_msg.c:2160 => fetch input
I (733665) mbedtls: ssl_msg.c:2300 in_left: 5, nb_want: 7
I (733675) mbedtls: ssl_msg.c:2320 in_left: 5, nb_want: 7
I (733685) mbedtls: ssl_msg.c:2323 ssl->f_recv(_timeout)() returned 2 (-0xfffffffe)
I (733685) mbedtls: ssl_msg.c:2345 <= fetch input
I (733695) mbedtls: ssl_msg.c:5027 got an alert message, type: [2:40]
W (733705) mbedtls: ssl_msg.c:5034 is a fatal alert message (msg 40)
W (733705) mbedtls: ssl_msg.c:4177 mbedtls_ssl_handle_message_type() returned -30592 (-0x7780)
W (733715) mbedtls: ssl_tls12_client.c:1197 mbedtls_ssl_read_record() returned -30592 (-0x7780)
I (733725) mbedtls: ssl_tls.c:3930 <= handshake
E (733735) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780
I (733745) esp-tls-mbedtls: Certificate verified.
E (733745) esp-tls: Failed to open new connection
E (733755) transport_base: Failed to open a new connection
E (733765) HTTP_CLIENT: Connection failed, sock < 0
I (733765) MQTT: HTTP_EVENT_ERROR
E (733765) MQTT: HTTP POST request failed: ESP_ERR_HTTP_CONNECT
I (733775) MQTT: Last esp error code: 0x801a
I (733775) MQTT: Last mbedtls failure: 0x7780
No response from server after POST request!
It is most likely shortage of internal RAM.
Also check this in config, i had issue recently when set to true with TLS
config.skip_cert_common_name_check = false;
Users browsing this forum: No registered users and 93 guests
