Running idf.py size-components while using idf_as_lib
uday.sriranga
Postby uday.sriranga » Fri Apr 12, 2024 2:30 pm
Hi
I'm using the example code provided here (https://github.com/espressif/esp-idf/tr ... idf_as_lib) to build my application.
After building I want to run idf.py size , idf.py size-components. Both of them return error.
udayms@pc:~/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib ((no branch))$ idf.py size-components
Executing action: size-components
Running ninja in directory /home/udayms/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib/build
Executing "ninja all"...
[1/4] cd /home/udayms/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib/build/esp-idf/esptool_py && /home/uda...table/partition-table.bin /home/udayms/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib/build/idf_as_lib.binidf_as_lib.bin binary size 0x22fc0 bytes. Smallest app partition is 0x100000 bytes. 0xdd040 bytes (86%) free.
[1/1] cd /home/udayms/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib/build/bootloader/esp-idf/esptool_py &...bootloader 0x0 /home/udayms/esp/esp-idf-v5.1.1/examples/build_system/cmake/idf_as_lib/build/bootloader/bootloader.binBootloader binary size 0x5040 bytes. 0x2fc0 bytes (37%) free.
Executing "ninja size-components"...
ninja: error: unknown target 'size-components'
I did look into other example and figured out that '.map' file is needed.
As I'm new to CMake , I couldn't generate the .map file even after spending couple of hours on it.
It would be helpful if someone guide me to generate .map file or provide steps to enable idf.py size-components
uday.sriranga
Re: Running idf.py size-components while using idf_as_lib
Postby uday.sriranga » Fri Apr 12, 2024 3:39 pm
I was able to generate a map file with following additions
set(idf_size ${python} -m esp_idf_size)
set(mapfile "${CMAKE_BINARY_DIR}/${CMAKE_PROJECT_NAME}.map")
target_link_options(${elf_file} PRIVATE "-Wl,--Map=${mapfile}")
and enable size-components command by
add_custom_target(size-components
    COMMAND ${CMAKE_COMMAND}
    -D "IDF_SIZE_TOOL=${idf_size}"
    -D "IDF_SIZE_MODE=--archives"
    -D "MAP_FILE=${mapfile}"
    -D "OUTPUT_JSON=${OUTPUT_JSON}"
    -P "${idf_path}/tools/cmake/run_size_tool.cmake"
    DEPENDS ${mapfile}
    USES_TERMINAL
    VERBATIM
Now I got a new error
[0/1] cd /u/tmp/bluefi/build && /usr/bin/cmake -D "IDF_SIZE_TOOL=/home/udayms/.espressif/python_env/idf5.1_py3.8_env/bin/python;-m;esp_idf_size" -D IDF_SIZE_MODE=--archives -D MAP_FILE=/u/tmp/bluefi/build/bluefi.map -D OUTPUT_JSON= -P /home/udayms/esp/esp-idf-v5.1.1/tools/cmake/run_size_tool.cmake
File "/usr/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/home/udayms/.espressif/python_env/idf5.1_py3.8_env/lib/python3.8/site-packages/esp_idf_size/__main__.py", line 4, in <module>
main()
File "/home/udayms/.espressif/python_env/idf5.1_py3.8_env/lib/python3.8/site-packages/esp_idf_size/core.py", line 513, in main
detected_target, segments, sections = load_map_data(args.map_file)
File "/home/udayms/.espressif/python_env/idf5.1_py3.8_env/lib/python3.8/site-packages/esp_idf_size/core.py", line 237, in load_map_data
detected_chip = detect_target_chip(map_file)
File "/home/udayms/.espressif/python_env/idf5.1_py3.8_env/lib/python3.8/site-packages/esp_idf_size/core.py", line 301, in detect_target_chip
raise RuntimeError('Target not detected')
RuntimeError: Target not detected
CMake Error at /home/udayms/esp/esp-idf-v5.1.1/tools/cmake/run_size_tool.cmake:42 (message):
failed
FAILED: CMakeFiles/size-components
ESP_Roland
Postby ESP_Roland » Mon Apr 15, 2024 6:06 am
Perhaps this is what you are missing:
        # Add this symbol as a hint for esp_idf_size to guess the target name
        target_link_options(${project_elf} PRIVATE "-Wl,--defsym=IDF_TARGET_${idf_target}=0")
uday.sriranga
Postby uday.sriranga » Tue Apr 16, 2024 4:46 am
Thanks ESP_Roland
This solved my issue
Users browsing this forum: Baidu [Spider], Bing [Bot] and 91 guests
