Problems using flash_download_tool_3.9.5
Posted: Sat Dec 09, 2023 2:55 pm
by pedrobravoz
Hello, we are trying to upload a firmware using version 3.9.5 and the upload gives an error:
D:\SKETCHS_REPOSITORY\SKETCH-PROJECTS\NAT-REUTER_ESP32\flash_download_tool_3.9.5
D:\SKETCHS_REPOSITORY\SKETCH-PROJECTS\NAT-REUTER_ESP32\esp32_nat_router-master\build\esp32\bootloader.bin
D:\SKETCHS_REPOSITORY\SKETCH-PROJECTS\NAT-REUTER_ESP32\esp32_nat_router-master\build\esp32\firmware.bin
D:\SKETCHS_REPOSITORY\SKETCH-PROJECTS\NAT-REUTER_ESP32\esp32_nat_router-master\build\esp32\partitions.bin
1 kill
2 kill
3 kill
test offset : 4096 0x1000
case ok
test offset : 65536 0x10000
case ok
test offset : 32768 0x8000
case ok
case ok
case ok
case ok
[2023-12-09 11:26:27,714][ESP8266Loader_spi[1]][espDownloader.py][line:741][ERROR]:
no log file output...
However, a colleague did the same process with the ESP32 FLASH DOWNLOAD TOOL V3.9.3 version and it worked perfectly.
This version is not available now, there is only the latest 3.9.5 which is heavier than the previous one.
Is it possible to get version V3.9.3???
Any idea what the problem might be?
Re: Problems using flash_download_tool_3.9.5
Posted: Sun Dec 10, 2023 7:36 pm
by mbratch
I have a copy of 3.9.3. I sent you a private message.
I did try 3.9.5 and it is working Ok for me.
