I am using ESP32 WROOM 32E for a project.
For this project I am using ADC to get voltage and current sensors value via ADC.
VOLTAGE_PIN ADC1_CHANNEL_7//33
CURRENT_PIN ADC1_CHANNEL_6//34
I need to calculate RMS Voltage & Current from this.
Can someone provide me with the data how much time it takes to get one ADC value and total samples for this calculation.
ADC Sampling rate
Re: ADC Sampling rate
The ESP32-WROOM-32E has a maximum sampling rate of 2Msps (2 Mega Samples per second) for each ADC channel. The time it takes to get one ADC value can be calculated as follows:ABHISHEK05 wrote: ↑Wed Mar 01, 2023 11:11 amI am using ESP32 WROOM 32E for a project.
Time to get one ADC value = 1 / Sampling rate = 1 / 2Msps = 0.5 microseconds
To calculate the RMS voltage and current, you will need to collect multiple ADC samples over a period of time. The number of samples required depends on the frequency of the signal you are measuring and the accuracy you require for your measurement. Typically, at least one cycle of the AC waveform is needed for an accurate RMS measurement.
If you are measuring a 50Hz AC signal, for example, you would need to collect at least 100 samples (2 full cycles of the waveform, assuming a 20ms period) to get an accurate RMS measurement. The time required to collect these samples would be:
Time for sampling = Time to get one ADC value * Number of samples = 0.5 microseconds * 100 = 50 microseconds
You can adjust the number of samples based on the frequency and accuracy requirements of your specific application.
"AskRudi"
see comments viewtopic.php?f=12&t=31822#p110339 about sampling rate. Above ~280K combined sample rate may not do what you expect.
Craige
Users browsing this forum: No registered users and 63 guests
