Using DAC2 on ESP32-S2-Mini-1U
Posted: Tue May 17, 2022 6:32 am
by MarkusR
the documentation says that this pin is pulled up to 3v3 via 10K resistor, if I want to use this DAC output does that mean I have to remove the shield and remove R11 first?
https://www.espressif.com/sites/default ... eet_en.pdf
The problem I see is that DAC 2 is stuck at 2.68V while DAC 1 just works fine.
Re: Using DAC2 on ESP32-S2-Mini-1U
Posted: Tue Jul 26, 2022 7:54 am
by yuliksan
Hi, MarcusR
Did you solve the problem?
Posted: Wed Feb 07, 2024 3:58 pm
by PepeTheGreat
Same issue. Why is there a 10k to vcc? To keep rx1 up?
Removing this should help: https://imgur.com/a/4MqclGo
