https simple example Error
Posted: Mon Nov 01, 2021 8:06 am
by Dansen
Hello guys!
im facing some problems with my Visual Studio / esp-idf extension.
I was trying Implementing the https example and it worked fine, until Friday, where suddenly this Error appears:
C:/Users/Student/esp/esp-idf/components/esp_https_server/include/esp_https_server.h:91:5: error: expected identifier or '(' before '.' token
.httpd = { \
C:/Users/Student/esp/esp-idf/components/esp_https_server/include/esp_https_server.h:112:5: error: expected identifier or '(' before '.' token
.cacert_pem = NULL, \
[16/299] Building C object esp-idf/expat/CMakeFiles/__idf_expat.dir/expat/expat/lib/xmlparse.c.obj
The terminal process "C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command cmake --build ." terminated with exit code: 1.
I was very suprised, since i did not touch the headerfile. After trying some stuff i just decided to load a fresh new example and delete my old file.
Now the same problem appears again, without me doing anything on my example-file.
Someone ever got the same problem and can help out?
Thanks in advance!
and here's the example code
/* Simple HTTP + SSL Server Example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <esp_wifi.h>
#include <esp_event.h>
#include <esp_log.h>
#include <esp_system.h>
#include <nvs_flash.h>
#include <sys/param.h>
#include "esp_netif.h"
#include "esp_eth.h"
#include "protocol_examples_common.h"
#include <esp_https_server.h>
/* A simple example that demonstrates how to create GET and POST
 * handlers and start an HTTPS server.
static const char *TAG = "example";
/* An HTTP GET handler */
static esp_err_t root_get_handler(httpd_req_t *req)
    httpd_resp_set_type(req, "text/html");
    httpd_resp_send(req, "<h1>Hello Secure World!</h1>", HTTPD_RESP_USE_STRLEN);
    return ESP_OK;
static const httpd_uri_t root = {
    .uri       = "/",
    .method    = HTTP_GET,
    .handler   = root_get_handler
static httpd_handle_t start_webserver(void)
    httpd_handle_t server = NULL;
    // Start the httpd server
    ESP_LOGI(TAG, "Starting server");
    httpd_ssl_config_t conf = HTTPD_SSL_CONFIG_DEFAULT();
    extern const unsigned char cacert_pem_start[] asm("_binary_cacert_pem_start");
    extern const unsigned char cacert_pem_end[]   asm("_binary_cacert_pem_end");
    conf.cacert_pem = cacert_pem_start;
    conf.cacert_len = cacert_pem_end - cacert_pem_start;
    extern const unsigned char prvtkey_pem_start[] asm("_binary_prvtkey_pem_start");
    extern const unsigned char prvtkey_pem_end[]   asm("_binary_prvtkey_pem_end");
    conf.prvtkey_pem = prvtkey_pem_start;
    conf.prvtkey_len = prvtkey_pem_end - prvtkey_pem_start;
    esp_err_t ret = httpd_ssl_start(&server, &conf);
    if (ESP_OK != ret) {
        ESP_LOGI(TAG, "Error starting server!");
        return NULL;
    // Set URI handlers
    ESP_LOGI(TAG, "Registering URI handlers");
    httpd_register_uri_handler(server, &root);
    return server;
static void stop_webserver(httpd_handle_t server)
    // Stop the httpd server
    httpd_ssl_stop(server);
static void disconnect_handler(void* arg, esp_event_base_t event_base,
                               int32_t event_id, void* event_data)
    httpd_handle_t* server = (httpd_handle_t*) arg;
    if (*server) {
        stop_webserver(*server);
        *server = NULL;
static void connect_handler(void* arg, esp_event_base_t event_base,
    if (*server == NULL) {
        *server = start_webserver();
void app_main(void)
    static httpd_handle_t server = NULL;
    ESP_ERROR_CHECK(nvs_flash_init());
    ESP_ERROR_CHECK(esp_netif_init());
    ESP_ERROR_CHECK(esp_event_loop_create_default());
    /* Register event handlers to start server when Wi-Fi or Ethernet is connected,
     * and stop server when disconnection happens.
#ifdef CONFIG_EXAMPLE_CONNECT_WIFI
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, WIFI_EVENT_STA_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_WIFI
#ifdef CONFIG_EXAMPLE_CONNECT_ETHERNET
    ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &connect_handler, &server));
    ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ETHERNET_EVENT_DISCONNECTED, &disconnect_handler, &server));
#endif // CONFIG_EXAMPLE_CONNECT_ETHERNET
    /* This helper function configures Wi-Fi or Ethernet, as selected in menuconfig.
     * Read "Establishing Wi-Fi or Ethernet Connection" section in
     * examples/protocols/README.md for more information about this function.
    ESP_ERROR_CHECK(example_connect());
and here is the headerfile I am getting Errors for
// Copyright 2018 Espressif Systems (Shanghai) PTE LTD
// Licensed under the Apache License, Version 2.0 (the "License");
// you may not use this file except in compliance with the License.
// You may obtain a copy of the License at
//     http://www.apache.org/licenses/LICENSE-2.0
// Unless required by applicable law or agreed to in writing, software
// distributed under the License is distributed on an "AS IS" BASIS,
// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
// See the License for the specific language governing permissions and
// limitations under the License.
#ifndef _ESP_HTTPS_SERVER_H_
#define _ESP_HTTPS_SERVER_H_
#include <stdbool.h>
#include "esp_err.h"
#include "esp_http_server.h"
#ifdef __cplusplus
extern "C" {
#endif
typedef enum {
    HTTPD_SSL_TRANSPORT_SECURE,      // SSL Enabled
    HTTPD_SSL_TRANSPORT_INSECURE     // SSL disabled
} httpd_ssl_transport_mode_t;
 * HTTPS server config struct
 * Please use HTTPD_SSL_CONFIG_DEFAULT() to initialize it.
struct httpd_ssl_config {
     * Underlying HTTPD server config
     * Parameters like task stack size and priority can be adjusted here.
    httpd_config_t httpd;
    /** CA certificate (here it is treated as server cert)
     * Todo: Fix this change in release/v5.0 as it would be a breaking change
     * i.e. Rename the nomenclature of variables holding different certs in https_server component as well as example
     * 1)The cacert variable should hold the CA which is used to authenticate clients (should inherit current role of client_verify_cert_pem var)
     * 2)There should be another variable servercert which whould hold servers own certificate (should inherit current role of cacert var) */
    const uint8_t *cacert_pem;
    /** CA certificate byte length */
    size_t cacert_len;
    /** Client verify authority certificate (CA used to sign clients, or client cert itself */
    const uint8_t *client_verify_cert_pem;
    /** Client verify authority cert len */
    size_t client_verify_cert_len;
    /** Private key */
    const uint8_t *prvtkey_pem;
    /** Private key byte length */
    size_t prvtkey_len;
    /** Transport Mode (default secure) */
    httpd_ssl_transport_mode_t transport_mode;
    /** Port used when transport mode is secure (default 443) */
    uint16_t port_secure;
    /** Port used when transport mode is insecure (default 80) */
    uint16_t port_insecure;
typedef struct httpd_ssl_config httpd_ssl_config_t;
 * Default config struct init
 * (http_server default config had to be copied for customization)
 * Notes:
 * - port is set when starting the server, according to 'transport_mode'
 * - one socket uses ~ 40kB RAM with SSL, we reduce the default socket count to 4
 * - SSL sockets are usually long-lived, closing LRU prevents pool exhaustion DOS
 * - Stack size may need adjustments depending on the user application
#define HTTPD_SSL_CONFIG_DEFAULT() {              \
    .httpd = {                                    \
        .task_priority      = tskIDLE_PRIORITY+5, \
        .stack_size         = 10240,              \
        .core_id            = tskNO_AFFINITY,     \
        .server_port        = 0,                  \
        .ctrl_port          = 32768,              \
        .max_open_sockets   = 4,                  \
        .max_uri_handlers   = 8,                  \
        .max_resp_headers   = 8,                  \
        .backlog_conn       = 5,                  \
        .lru_purge_enable   = true,               \
        .recv_wait_timeout  = 5,                  \
        .send_wait_timeout  = 5,                  \
        .global_user_ctx = NULL,                  \
        .global_user_ctx_free_fn = NULL,          \
        .global_transport_ctx = NULL,             \
        .global_transport_ctx_free_fn = NULL,     \
        .open_fn = NULL,                          \
        .close_fn = NULL,                         \
        .uri_match_fn = NULL                      \
    .cacert_len = 0,                              \
    .client_verify_cert_pem = NULL,               \
    .client_verify_cert_len = 0,                  \
    .prvtkey_pem = NULL,                          \
    .prvtkey_len = 0,                             \
    .transport_mode = HTTPD_SSL_TRANSPORT_SECURE, \
    .port_secure = 443,                           \
    .port_insecure = 80,                          \
 * Create a SSL capable HTTP server (secure mode may be disabled in config)
 * @param[in,out] config - server config, must not be const. Does not have to stay valid after
 *                         calling this function.
 * @param[out] handle - storage for the server handle, must be a valid pointer
 * @return success
esp_err_t httpd_ssl_start(httpd_handle_t *handle, httpd_ssl_config_t *config);
 * Stop the server. Blocks until the server is shut down.
 * @param[in] handle
void httpd_ssl_stop(httpd_handle_t handle);
#ifdef __cplusplus
#endif
#endif // _ESP_HTTPS_SERVER_H_
