ESP32 custom partition table.
Posted: Tue Sep 15, 2020 5:15 am
Currently I am facing problem to create custom partition in ESP32.
I have created the custom partition settings in munuconfig/partition/custom partition settings and sdkconfig i have saved.
I have created the custom_partition.csv file and kept it in the below path.
C:\Users\Akshata\Desktop\esp-idf\examples\get-started\hello_world\build\partition_table
as the documents have given the guidelines.
when i build my code i got this error
C:\Users\Akshata\Desktop\esp-idf\examples\get-started\hello_world>idf.py build
Note: You are using Python 3.7.3. Python 3 support is new, please report any problems you encounter. Search for 'Setting the Python Interpreter' in the ESP-IDF docs if you want to use Python 2.7.
Checking Python dependencies...
Python requirements from C:\Users\Akshata\Desktop\esp-idf\requirements.txt are satisfied.
Running ninja in directory C:\Users\Akshata\Desktop\esp-idf\examples\get-started\hello_world\build
Executing "ninja all"...
[0/1] Re-running CMake...
-- Building for target esp32
-- ccache will be used for faster builds
-- Building empty aws_iot component due to configuration
-- Component names: soc log heap xtensa-debug-module app_trace freertos vfs newlib esp_ringbuf driver esp_event ethernet mbedtls micro-ecc efuse bootloader_support partition_table app_update spi_flash nvs_flash lwip tcpip_adapter pthread smartconfig_ack wpa_supplicant espcoredump esp32 cxx asio jsmn aws_iot bootloader nimble bt coap console nghttp esp-tls esp_adc_cal tcp_transport esp_http_client esp_http_server esp_https_ota openssl esp_https_server esptool_py expat wear_levelling sdmmc fatfs freemodbus idf_test json libsodium mdns mqtt protobuf-c protocomm spiffs ulp unity wifi_provisioning main
-- Component paths: C:/Users/Akshata/Desktop/esp-idf/components/soc;C:/Users/Akshata/Desktop/esp-idf/components/log;C:/Users/Akshata/Desktop/esp-idf/components/heap;C:/Users/Akshata/Desktop/esp-idf/components/xtensa-debug-module;C:/Users/Akshata/Desktop/esp-idf/components/app_trace;C:/Users/Akshata/Desktop/esp-idf/components/freertos;C:/Users/Akshata/Desktop/esp-idf/components/vfs;C:/Users/Akshata/Desktop/esp-idf/components/newlib;C:/Users/Akshata/Desktop/esp-idf/components/esp_ringbuf;C:/Users/Akshata/Desktop/esp-idf/components/driver;C:/Users/Akshata/Desktop/esp-idf/components/esp_event;C:/Users/Akshata/Desktop/esp-idf/components/ethernet;C:/Users/Akshata/Desktop/esp-idf/components/mbedtls;C:/Users/Akshata/Desktop/esp-idf/components/micro-ecc;C:/Users/Akshata/Desktop/esp-idf/components/efuse;C:/Users/Akshata/Desktop/esp-idf/components/bootloader_support;C:/Users/Akshata/Desktop/esp-idf/components/partition_table;C:/Users/Akshata/Desktop/esp-idf/components/app_update;C:/Users/Akshata/Desktop/esp-idf/components/spi_flash;C:/Users/Akshata/Desktop/esp-idf/components/nvs_flash;C:/Users/Akshata/Desktop/esp-idf/components/lwip;C:/Users/Akshata/Desktop/esp-idf/components/tcpip_adapter;C:/Users/Akshata/Desktop/esp-idf/components/pthread;C:/Users/Akshata/Desktop/esp-idf/components/smartconfig_ack;C:/Users/Akshata/Desktop/esp-idf/components/wpa_supplicant;C:/Users/Akshata/Desktop/esp-idf/components/espcoredump;C:/Users/Akshata/Desktop/esp-idf/components/esp32;C:/Users/Akshata/Desktop/esp-idf/components/cxx;C:/Users/Akshata/Desktop/esp-idf/components/asio;C:/Users/Akshata/Desktop/esp-idf/components/jsmn;C:/Users/Akshata/Desktop/esp-idf/components/aws_iot;C:/Users/Akshata/Desktop/esp-idf/components/bootloader;C:/Users/Akshata/Desktop/esp-idf/components/nimble;C:/Users/Akshata/Desktop/esp-idf/components/bt;C:/Users/Akshata/Desktop/esp-idf/components/coap;C:/Users/Akshata/Desktop/esp-idf/components/console;C:/Users/Akshata/Desktop/esp-idf/components/nghttp;C:/Users/Akshata/Desktop/esp-idf/components/esp-tls;C:/Users/Akshata/Desktop/esp-idf/components/esp_adc_cal;C:/Users/Akshata/Desktop/esp-idf/components/tcp_transport;C:/Users/Akshata/Desktop/esp-idf/components/esp_http_client;C:/Users/Akshata/Desktop/esp-idf/components/esp_http_server;C:/Users/Akshata/Desktop/esp-idf/components/esp_https_ota;C:/Users/Akshata/Desktop/esp-idf/components/openssl;C:/Users/Akshata/Desktop/esp-idf/components/esp_https_server;C:/Users/Akshata/Desktop/esp-idf/components/esptool_py;C:/Users/Akshata/Desktop/esp-idf/components/expat;C:/Users/Akshata/Desktop/esp-idf/components/wear_levelling;C:/Users/Akshata/Desktop/esp-idf/components/sdmmc;C:/Users/Akshata/Desktop/esp-idf/components/fatfs;C:/Users/Akshata/Desktop/esp-idf/components/freemodbus;C:/Users/Akshata/Desktop/esp-idf/components/idf_test;C:/Users/Akshata/Desktop/esp-idf/components/json;C:/Users/Akshata/Desktop/esp-idf/components/libsodium;C:/Users/Akshata/Desktop/esp-idf/components/mdns;C:/Users/Akshata/Desktop/esp-idf/components/mqtt;C:/Users/Akshata/Desktop/esp-idf/components/protobuf-c;C:/Users/Akshata/Desktop/esp-idf/components/protocomm;C:/Users/Akshata/Desktop/esp-idf/components/spiffs;C:/Users/Akshata/Desktop/esp-idf/components/ulp;C:/Users/Akshata/Desktop/esp-idf/components/unity;C:/Users/Akshata/Desktop/esp-idf/components/wifi_provisioning;C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/main
-- IDF_VER: v3.3.2
-- Project version: v3.3.2
CMake Warning at C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:13 (message):
Partition table CSV file
C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/partitions.csv
not found. Change custom partition CSV path in menuconfig.
C:/Users/Akshata/Desktop/esp-idf/tools/cmake/utilities.cmake:104 (include)
C:/Users/Akshata/Desktop/esp-idf/tools/cmake/idf_functions.cmake:401 (include_if_exists)
C:/Users/Akshata/Desktop/esp-idf/tools/cmake/project.cmake:173 (idf_import_components)
CMakeLists.txt:6 (project)
CMake Warning at C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:43 (message):
parttool.py execution failed (), problem with partition CSV file (see
above)
C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:55 (get_partition_info)
above)
C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:58 (get_partition_info)
above)
C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:61 (get_partition_info)
above)
C:/Users/Akshata/Desktop/esp-idf/components/partition_table/project_include.cmake:64 (get_partition_info)
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- Adding linker script C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script C:/Users/Akshata/Desktop/esp-idf/components/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Users/Akshata/Desktop/esp-idf/components/esp32/ld/esp32.peripherals.ld
-- Adding linker script C:/Users/Akshata/Desktop/esp-idf/components/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Users/Akshata/Desktop/esp-idf/components/esp32/ld/esp32.rom.spiram_incompatible_fns.ld
-- Component libraries:
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/build
[215/672] cmd.exe /C "cd /D C:\Users\Akshata\Desktop\esp-idf\examples\get-started\hello_world...make\3.13.4\bin\cmake.exe -P C:/Users/Akshata/Desktop/esp-idf/tools/cmake/scripts/fail.cmake"
FAILED: esp-idf/partition_table/CMakeFiles/partition_table
cmd.exe /C "cd /D C:\Users\Akshata\Desktop\esp-idf\examples\get-started\hello_world\build\esp-idf\partition_table && C:\Users\Akshata\.espressif\tools\cmake\3.13.4\bin\cmake.exe -E echo "Partition table CSV C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/partitions.csv does not exist." && C:\Users\Akshata\.espressif\tools\cmake\3.13.4\bin\cmake.exe -E echo "Either change partition table in menuconfig or create this input file." && C:\Users\Akshata\.espressif\tools\cmake\3.13.4\bin\cmake.exe -E touch C:/Users/Akshata/Desktop/esp-idf/examples/get-started/hello_world/build/CMakeCache.txt && C:\Users\Akshata\.espressif\tools\cmake\3.13.4\bin\cmake.exe -P C:/Users/Akshata/Desktop/esp-idf/tools/cmake/scripts/fail.cmake"
CMake Error at C:/Users/Akshata/Desktop/esp-idf/tools/cmake/scripts/fail.cmake:3 (message):
Failing the build (see errors on lines above)
[224/672] Building C object esp-idf/app_update/CMakeFiles/idf_component_app_update.dir/esp_app_desc.c.obj
ninja failed with exit code 1
i need help in this where I am going wrong whether in Path of csv file or any extra linking procedure which here is missing because CSV file not found at given position.
-- IDF_VER: v3.3.2
above)
above)
above)
above)
-- Configuring done
-- Generating done
