MD5 sum error when flashing code in second time
Posted: Wed Mar 11, 2020 11:26 am
by Aniket Patel
Hi all,
I have removed the shield(upper cover) on the ESP32-WROVER module and replaced the internal 4 MB flash with 16 MB flash(CYPRESS S25FL127S) to increase the esp32 module flash size. when first time flashing this module then module successfully flashing and working fine, but when I flash the second time then module gives MD5 error in the console log.
But when I erase the entire flash and then upload the code It works fine.
ESP32 module Flashing Log:-
aniket@aniket-Desktop:~/Projects/Ayla_B_bridge/Software/B_Bridge_Firmware/GIT/Git_Common_checkout/Ayla-B_Bridge/Firmware/source/development/B_Bridge_app(ABB_807)$ make flash monitor
Toolchain path: /home/aniket/Projects/Ayla_B_bridge/Software/B_Bridge_Firmware/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a
Compiler version: 5.2.0
Python requirements from /home/aniket/Projects/Ayla_B_bridge/Software/B_Bridge_Firmware/esp-idf/requirements.txt are satisfied.
Flashing binaries to serial port /dev/ttyUSB0 (app at offset 0x10000)...
esptool.py v2.6
Serial port /dev/ttyUSB0[attachment=1]Screenshot from 2020-03-11 16-33-46.png[/attachment][attachment=1]Screenshot from 2020-03-11 16-29-33.png[/attachment]
Connecting....
Chip is ESP32D0WDQ5 (revision 1)
MAC: c8:2b:96:99:fc:fc
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Compressed 8192 bytes to 31...
Wrote 8192 bytes (31 compressed) at 0x0000a000 in 0.0 seconds (effective 4085.8 kbit/s)...
Hash of data verified.
Compressed 20192 bytes to 12241...
Wrote 20192 bytes (12241 compressed) at 0x00001000 in 0.1 seconds (effective 1121.9 kbit/s)...
Compressed 1522352 bytes to 919134...
Wrote 1522352 bytes (919134 compressed) at 0x00010000 in 20.6 seconds (effective 590.4 kbit/s)...
File  md5: 3ed193a4092b48460b8d8ecee91103ea
Flash md5: fcaa9b9e393954c0162ef7ca16b0bb22
MD5 of 0xFF is f4e89d1ccdf97d3d2d6db9691a1abd8d
A fatal error occurred: MD5 of file does not match data in flash!
/home/aniket/Projects/Ayla_B_bridge/Software/B_Bridge_Firmware/esp-idf/components/esptool_py/Makefile.projbuild:62: recipe for target 'flash' failed
make: *** flash Error 2
aniket@aniket-Desktop:~/Projects/Ayla_B_bridge/Software/B_Bridge_Firmware/GIT/Git_Common_checkout/Ayla-B_Bridge/Firmware/source/development/B_Bridge_app(ABB_807)$ make erase_flash
Erasing entire flash...
esptool.py v2.6
Connecting........_____....._
Uploading stub...
Running stub...
Stub running...
Changed.
Erasing flash (this may take a while)...
Chip erase completed successfully in 41.0s
Hard resetting via RTS pin...
esptool.py v2.6
Uploading stub...
Running stub...
Stub running...
Changed.
Wrote 8192 bytes (31 compressed) at 0x0000a000 in 0.0 seconds (effective 4097.8 kbit/s)...
Wrote 20192 bytes (12241 compressed) at 0x00001000 in 0.1 seconds (effective 1122.4 kbit/s)...
Wrote 1522352 bytes (919134 compressed) at 0x00010000 in 21.3 seconds (effective 572.6 kbit/s)...
Compressed 3072 bytes to 135...
Wrote 3072 bytes (135 compressed) at 0x00008000 in 0.0 seconds (effective 1550.0 kbit/s)...
Leaving...
Re: MD5 sum error when flashing code in second time
Posted: Thu Mar 12, 2020 8:32 am
by ESP_Sprite
Not sure if we support that flash; it may have a different sector erase command. If it does, erasing flash 'on the fly' like what happens when you over-write flash won't work and you will get data errors.
Posted: Fri Mar 13, 2020 6:27 am
by Aniket Patel
Hi ESP_sprite,
Thanks for your quick reply, currently we have changed 16 MB flash from CYPRESS S25FL127S to Winbond W25Q128FW then I have tested the device. It's working fine.
