Page 1 of 2
Low voltage on all pins, even 5v and 3.3v [RESOLVED]
Posted: Sun Apr 14, 2019 3:54 pm
by wiserorb
I was trying to power a simple led, but when I set the output high it flickered. So i measured the voltage whit an external multimeter and it said 0.3v! So I tested the voltage on 5v and it was 1.8, on 3.3v was 0.3.
Despite this the board was in softAP mode and communicating with the computer.
P.S. Sorry for my bad english
Edit:
The bad measurement were caused by an error on the serygraphy of the board. The pin that I was thinking was ground is instead the CMD pin.
Here is the code, but I don't this is important
#include <WiFi.h>
#include "FS.h"
#include "SPIFFS.h"
#define CORE 1
#define LED_BUILTIN 26
const char *ssid = "esp32";
WiFiServer server(80);
File icon;
void setup() {
pinMode(LED_BUILTIN,INPUT_PULLUP);
Serial.begin(115200);
Serial.println();
if(!SPIFFS.begin(true)){
Serial.println("SPIFFS failed");
WiFi.softAP(ssid);
IPAddress myIP = WiFi.softAPIP();
Serial.println("ESP32 IP:");
Serial.println(myIP);
server.begin();
Serial.println("Server started");
xTaskCreatePinnedToCore(
TaskRespondeToClient
, "Responde Task"
, 4096
, NULL
, 2
, NULL
, CORE);
void loop() {
delay(1);
void TaskRespondeToClient(void *par) {
while (true) {
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New Client."); // print a message out the serial port
String currentLine = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
currentLine += c;
if (c == '\n') {
if (currentLine.length() == 0) {
sendResponse(client);
break;
Serial.println("----fromClient: " + currentLine);
currentLine = "";
readLine(currentLine, client);
client.stop();
Serial.println("Client Disconnected.");
void sendResponse(WiFiClient client) {
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<font size=\"32\">");
client.print("Click <a href=\"/H\">here</a> to turn ON the LED.<br>");
client.print("Click <a href=\"/L\">here</a> to turn OFF the LED.<br>");
client.print("</font>");
// The HTTP response ends with another blank line:
client.println();
void readLine(String inputLine, WiFiClient client) {
// Check to see if the client request was "GET /H" or "GET /L":
if (inputLine.endsWith("GET /H")) {
Serial.println("Led on");
digitalWrite(LED_BUILTIN, HIGH); // GET /H turns the LED on
if (inputLine.endsWith("GET /L")) {
Serial.println("Led off");
digitalWrite(LED_BUILTIN, LOW); // GET /L turns the LED off
if (inputLine.endsWith("GET /favicon.ico")) {
Serial.println("Sending icon");
client.println(F("HTTP/1.1 200 OK\n"
"Content-Type: image/x-icon\n"
"Connection: keep-alive\n"));
icon=SPIFFS.open("/favicon.ico");
if(icon.isDirectory()){
Serial.println("icon opened");
while(icon.available()){
client.write(icon.read());
icon.close();
client.println();
Re: Low voltage on all pins, even 5v and 3.3v
Posted: Mon Apr 15, 2019 5:34 am
by ESP_Angus
I don't know why you're not able to read voltages correctly, but the pin mode should probably be OUTPUT not INPUT_PULLUP.
Posted: Tue Apr 16, 2019 6:41 pm
by wiserorb
OH yes, that was an experimental change to find a solution . If I put the gpio as OUTPUT i get the same results
Posted: Wed Apr 17, 2019 3:22 am
by commando_j
Check with scope if you can. Your meter would average out the reading if its fluctuating continuously quickly enough.
What is your power supply? Make sure it is not current limiting.
Do you have anything on the console? Do you see any reset? It also seems like it gets a short or current limit every time the code executes and resets. This would explain the LED flickering (turning on for a short time, then a short or over-current occurs, resetting the unit. The reset removes the short but when the code tries to turn on the LED again, you fall into the same loop.)
If you erase the ESP32, do you see normal voltage with the meter?
Posted: Thu Apr 18, 2019 12:12 pm
by wiserorb
Ok, I both erased and flashed idf hello_word in the board, but I get the same results. In the console there isn't any reboot.
I tried to power the esp32 with a PC port and a wall adapter with 2 ampere, but nothing changed. However programs run flawlessly.
Posted: Thu Apr 18, 2019 3:29 pm
by commando_j
When you mean it runs flawlessly, I assume you mean it compiled and downloaded without error?
You are still seeing the power fluctuations with the hello world?
When the board is erased, do you still see the power fluctuations?
If so, check if the AMS1117 regulator is getting hot. It may be blown, causing a short internally and going to thermal shutdown loop.
Posted: Fri Apr 19, 2019 11:14 am
by wiserorb
I mean that it doesn't restart, it prints out the things that it has to print, it has no problem except that low voltage thing.
I get the same lectures (1.8v on 5v pin and 0.4v on 3.3v pin) whit hello word and after i erased the board.
Now i'm going to buy a new one, and check if the problem is limited to my board.
Posted: Sun Apr 21, 2019 6:13 am
by commando_j
Just to be sure, do you have something else you can read with your meter? A separate source, like a desktop power supply with 12V output, with nothing connected to it. Just to ensure your meter is set right. It's not set to AC voltage is it? Some meters default every time you turn them on to AC.
Can you get your hands on a scope?
I'm questioning your instrument because at 0.4V the ESP32 would not run at all.
Posted: Wed May 01, 2019 5:09 pm
by wiserorb
Ok, after some serious headache I got it.
If I take the ground on the GND-pin near 5v I get all those strange measurement, but if I take it in the other side of the board i get the full volts I'm expecting.
Do you have some explanation of this behavior?
P.S this happens on both board I have
Posted: Wed May 01, 2019 11:40 pm
by WiFive
Are you sure that's not the CMD pin?
