I do have the Arduino version working. If I try to install the esp-idf through the command line, I get this error: Installing tools: xtensa-esp32-elf, xtensa-esp32s2-elf, xtensa-esp32s3-elf, riscv32-esp-elf, esp32ulp-elf, esp32s2ulp-elf, openocd-esp32
ERROR: tool xtensa-esp32-elf does not have versions compatible with platform linux-arm64
I am working through some blogs, but nothing works so far. Have not given up yet.
Tool xtensa-esp32-elf-gcc is not available for Raspberry Pi (ARM)
Re: Tool xtensa-esp32-elf-gcc is not available for Raspberry Pi (ARM)
Ok. I got it working. Instead of using the instructions and following the links in :
https://docs.espressif.com/projects/esp ... stallation
I went to your website directly and downloaded the esp-idf 5.1 for esp32c3:
https://www.espressif.com/en/support/do ... %5B%5D=785
Worked like a champ.
I have just tried the installation procedure above and I get the same error. You may have provided arm64 binaries but the installation procedure fails with this message "ERROR: tool xtensa-esp32-elf does not have versions compatible with platform linux-arm64"ESP_Sprite wrote: ↑Tue Aug 22, 2023 1:30 amI think we've been providing arm64 binaries in our standard installation process for ages now... does the procedure at https://docs.espressif.com/projects/esp ... setup.html not work for you?
Users browsing this forum: axellin and 55 guests
