Initial flash needed for download boot over internal USB?
Fundeckhermit
Postby Fundeckhermit » Fri Apr 01, 2022 2:56 pm
I want to design a minimal PCB around the ESP32-S2-MINI with just:
  • Crystal circuit
  • Boot/Reset button
  • USB connector directly on D+ and D-
  • Voltage regulator
Can I use IDF to download a fresh/new/empty ESP32-S2-MINI with just the internal USB?
OR do I need JTAG/UART for the initial flashing?
Re: Initial flash needed for download boot over internal USB?
Postby ESP_Sprite » Fri Apr 01, 2022 2:58 pm
Yes, you can; the ROM contains a driver that can flash the device over USB. You do need a way to be able to put it into download mode by grounding GPIO0, though.
Fundeckhermit
Postby Fundeckhermit » Fri Apr 01, 2022 3:18 pm
So this would work?
Flashing a binary file with IDF on a new/fresh/empty ESP32-S2 over the internal USB (USB-OTG) peripheral.
Postby ESP_Sprite » Sat Apr 02, 2022 1:21 am
Yes, given that you put the chip into download mode by starting with GPIO0 low.
don.vukovic
Postby don.vukovic » Mon May 09, 2022 5:54 pm
Is there a page that describes this functionality ?
Are there example code available ?
Postby ESP_Sprite » Tue May 10, 2022 1:57 am
I'm not sure if there's a page describing this aside from mentions that you can also flash over USB here and there.What code example would you need? The USB port exposes an industry-standard CDC-ACM serial port (over which you can use the same protocol as when you use UART) and DFU endpoints.
Users browsing this forum: No registered users and 136 guests
